Results 11 to 20 of 22
Thread: Used MM phono stage advice
    I'm Gary.
    I have a Project Tube Box II with upgraded valves, PM me if interested.
    Gary
    I'm Drew.
    I know it's over budget but ......
    https://rover.ebay.com/rover/0/0/0?m...2F301892991405
    Just can't go wrong for that money.
    Yes...There was a Croft RIAA R on ebay until a few days ago for not much more but procrastination beat me to it...
    There's better value in the used market and that's where i'd aim TBH
    Yes...There was a Croft RIAA R on ebay until a few days ago for not much more but procrastination beat me to it :-(...
    I'm Drew.
    Also considering a Graham Slee Reflex M but yet to find one used...
    Loading is really easy to change if you can solder
    I got great results with the ptg33 ha500 and mani.
    However loading shouldn't be an issue as he's using the Ha500
    Steve...
    Turntable; Rega p8
    Cartridge; Alpheta mc
    Amplifier; Rega Elicit
    Speakers; Rega Rx3
    I'm Drew.
    Quote Originally Posted by STD305M View Post
    Steve...
    That's what I thought, the head amp should cover that
    Bigman80 Guest
    Quote Originally Posted by da2222 View Post
    A costly mistake. They are serious phonostages. If I had £500 for a phonostage and couldn't (nearly) build my own, that's where id go.
    I'm Drew.
    Yep, a costly mistake indeed... A review banging on about 'wooly' bass response kept my finger off the trigger. And the size!
    Bigman80 Guest
    Ah, well, in my experience, bass quality is largely dependent on what valves are used.
    I had Mullards, soft bass, swapped to Telefunken and the bass detail soared. Admittedly the Mullard weren't originals.
    I'm steve.
    Steve...
    Didn’t cotton on that he was using a head amp, that said the Mani should work fine.
    Bigman80 Guest
    https://r.tapatalk.com/shareLink?url...7&share_type=t
    FS: Firebottle Plus MM/MC Phonostage
