Results 11 to 20 of 21
Thread: Advice re mat on thorens td-160 super
    I'm Tim.
    The mat factors at work (dampening/muffling, isolating/static, soft/hard...) are complex (depending on the phono gear chain), one's use and to one's ear; subjective some.
    So trials are still the best way to find out what suits best one ear and the phono chain. There is no universal absolute better when it comes to phono.
    As about the thickness of the/your mat, don't forget that you can re-adjust your VTA accordingly if ever.
    - Cart Denon DL-102 in bakelite Ortofon SPU 'G' type headshell
    - TA SME 3009 'Improved' converted in heavy mass with detachable headshell
    - TT Thorens TD160 'E' totally tweaked driven by an 'Eagle & RoadRunner' PSU & tachometer combo
    - Matts top to bottom: leather, cork, felt & 12" vinyl
    - Pre-amp 'Modulis' Isem
    - Amp 'Exampli' Etalon 2x40W
    - Speakers 12" Leak 'Sandwich' first generation creatively recapped
    I'm Shaun.
    I got rid of my analogue gear earlier this year but up to that point I had a TD160 BC with a 5mm Achromat. It also had a solid maple plinth by Layers Of Beauty. Gorgeous deck.
    I'm Philip.
    Mine has a birch ply plinth from das accoustics in germany, via a nice aos member.
    Really like the looks and sound.
    I can see a cartridge upgrade looming. Ulp.
    Stick to something light weight. Remember you don't want to upset the delicate spring system. Cork's pretty good. HAve you considered Oscar's GIMP mat? I use this to great effect on my Lenco 75. It's 3mm thick and worth the money just for the experimental fun.
    PRE
    I'm Patrick.
    Is the orginal thorens mat as bad as it's sometimes made out to be?
    Quote Originally Posted by Simon75 View Post
    No it's just that it's been superseded by things that make the deck sound better.
    PRE
    I'm Philip.
    Is that the analogue works foam gimp mat?
    I'm Philip.
    I used a 3mm acromat and found it the right thickness for my thorens
    Strugglng to find one with label recess.
    Does it need a label recess?
    Hum.
    Crike....turntables are In another world of faffing/fettling.
    I never realis3d.
    I'm Shaun.
    No disrespect to anyone but I tried a cork mat on my TD160 and also a white acrylic one. Neither was a patch on the Achromat. Bloody expensive yeah but what a difference.
    I'm Shaun.
    Quote Originally Posted by philv View Post
    I never realis3d.
    LOL, one of the reasons it is no longer for me. Too bloody old and far to bloody cynical.
