Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Advice re mat on thorens td-160 super
    I'm Philip.
    Default Advice re mat on thorens td-160 super
    I have a thorens td-160 super with rb300 and sumiko pearl cartridge.
    If i use an acronat of 5mm thick, will thatbbe ok?
    It won’t throw off vta (whatever that is!) etc?
    I’m contemplating trying a 5mm actonat or 3mm cork/rubber mat.
    Thanks.
    I used a 3mm acromat and found it the right thickness for my thorens
    I'm jamie.
    it all depends on how thick your existing mat is.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Philip.
    Hum.
    How thick is a standard thorens rubber mat?
    I can use a felt mat and a thorens rubber mat under at the same time without problem.
    My eye sught has an error margin of + or - 50% when talking about 5mm.
    That’s using a mobile phone magnifier.
    I'm Philip.
    It might be a little close with a 5mm mat.
    Though i think a 3mm mat will fit.
    Bugger.....there’s a used 5mm acronat listed.
    Might try a rubber cork if i can’t find a 3mm acromat.
    I preferred my 2 piece rubber/cork blend and it was cheaper
    I'm Philip.
    Yes...9.99 or best offer.
    https://rover.ebay.com/rover/0/0/0?m...2F391397553555
    Like this one?
    Was a bit like this I think
    Top slip had a space for record label to fit in
    I'm Philip.
    Ah. See what you mean.
    Thanks.
    I'm Stephen.
    That’s exactly the one I settled on for my TD150 - tried a few different ones but from memory they all sounded “dull” compared to the cork/rubber mat but it’s a long time since I fitted and forgot
    Always a little further
