Results 1 to 5 of 5
Thread: Sony-UBP-X800-Blu-Ray DEAL ON AMAZON
    Default Sony-UBP-X800-Blu-Ray DEAL ON AMAZON
    Just noticed this deal on Amazon
    https://www.amazon.co.uk/Sony-UBP-X8...MX6GMJ95F4W0XC
    Might be of interest to some.
    I'm John.
    I've in the past thought a Oppo was a worth while investigation to achieve a multi media set up at home.
    The HD TV, is 14 years old now, so a modern TV, is on the horizon.
    My digital media experiences as seen on our TV, is achieved through a download to a laptop and then the laptop is connected by HDMI to the TV.
    How does the Sony model, make the user interface a improved experience
    This model is a much cheaper alternative to a Oppo, it looks like it can be used as a CD Transport as well,
    as I've got a want to have a CDT with the new recently purchased DAC, this seems to be worth a punt,
    as it has all the other benefits of usage as well.
    The DAC in use, has USB and Digital Coax Connection only, so I will need to check out connections are compatible.
    Can the 4TB Passport Portable HD, with a FLAC File Storage, be connected to it, so it can be used as a alternative to a computer to replay music files or TV media. ?
    How can a device like this be used to support a venture into Digital Music replays in a HiFi system and the beginnings of a AV system ?
    should do. it can stream from another source wirelessly and would think its got a usb in but read the pdf to see...http://bit.ly/2oQvSJ2
    I'm John.
    Brilliant !, it ticks all of the boxes as it has Digital Coax, and Parental Control to lock the better half out
    Joking put aside, it offers a multi usage format, that when one method of usage is obsolete, it will still have a relevant purpose for other applications.
    I am closer to getting a trial period put into place with a Music Replay Software.
    I was also advised recently to consider listening to a modern media player, such as a DVD/BluRay, as a CDT, as there has been much engineering thought put into the stability of the disc drives.
    Quote Originally Posted by JohnG View Post
    IME it's pot luck as regards to that. I've got a Samsung Blu-Ray player and as a CD transport it's diabolical. Performance of a transport depends on how much noise it generates and passes on to the external DAC. A good transport will have had attention paid to the power supplies so that doesn't happen. Most of these mass-market media players will not have had any of that, the power supply will be the bare minimum required to do the job.
    I can recommend the Oppos as being pretty good used as a CD player through their analogue outputs though.
