Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 114
Thread: LDR preamp build
  1. #21
    Interesting to see how one of these compares to a UK-Legal Khozmo 'pot-in-a-box' of similar resistance value. Both are passive types I understand.
  2. #22
    Thumbs up Captain Cadmium
    Quote Originally Posted by Edwardlon View Post
    A little bird informs me an LDR pre has landed and awaiting test and feedback here.
    Hello Marco.
    Yes, but unfortunately life is getting in the way!
    Hopefully, I'll get some time during the week to fire her up.
  3. #23
    I'm Rob.
    I built one years ago and it is the best pre I have....IMO of course. Not using a Pre now....and that is even better.
    https://youtu.be/ZCBe7-6rw4M
  4. #24
    I'm Edward.
    Quote Originally Posted by Puffin View Post
    I have an LDR pre but with 8 year old boards. Am waiting for the new boards which the maker Chris says is is even better. The current one is very good. Detailed, transparent, uncolored and just lets the music flow.
    How are you attenuating things?
  5. #25
    Bigman80 Guest
    What do you mean by "UK-Legal Khozmo" Dave?
  6. #26
    Suspect it's a subtle reference to the legal RoHS status (in the EU, and hence the UK) of devices using cadmium sulphide.
    Think it depends on the PPM as stated below. Looks like its permitted to have less than 100ppm...
    RoHS Restricted Substances
    RoHS specifies maximum levels for the following 10 restricted materials. The first six applied to the original RoHS while the last four were added under RoHS 3.
    Lead (Pb): < 1000 ppm
    Lead is commonly used in the electrical and electronics industry in solder, lead-acid batteries, electronic components, cable sheathing and in the glass of cathode-ray tubes.
    Mercury (Hg): < 100 ppm
    Mercury is widely used metals in the production of electrical and electronic appliances and is concentrated in batteries, switches and thermostats, and fluorescent lamps.
    Cadmium (Cd): < 100 ppm
    Cadmium is used in electronic equipment, car batteries, and pigments.
    Hexavalent Chromium (Cr VI) < 1000 ppm
    While some forms of chromium are non-toxic, Chromium VI can produce toxic effects.
    Polybrominated Biphenyls (PBB): 1000 ppm
    These are flame retardants found in electronic and electrical appliances. They have been found in indoor dust and air through evaporation from plastics.
    Polybrominated Diphenyl Ethers (PBDE): < 1000 ppm
    These are also flame retardants found in electronic and electrical appliances. Combustion of printed wiring boards release toxic emissions.
    Bis(2-Ethylhexyl) phthalate (DEHP): < 1000 ppm
    These are used to soften PVC and vinyl insulation on electrical wires.
    Benzyl butyl phthalate (BBP): < 1000 ppm
    Dibutyl phthalate (DBP): < 1000 ppm
    Diisobutyl phthalate (DIBP): < 1000 ppm
    I'm Rob.
    I built mine P2P with a schematic posted on Diyaudio. I always thought that the LDR's would have a finite life, but many years on they are still going. The 100k pot is (I have always understood, but someone might correct me) a voltage control. The design as many others has variable resistors to give some control over channel imbalance given the nature of LDR's. However I use 2 additional pots that give much greater control over balance and work to very good effect.
  9. #29
    Bigman80 Guest
    I don't think I am too worries about it. Legal or not, it sounds superb.
  10. #30
    Bigman80 Guest
    Looks like a really tidy build. Looking forward to reading the feedback.
    Can it oust Marcos Croft pre?
