Results 1 to 8 of 8
Thread: Kondo IO-J £2450
    I'm Ritchie.
    Default Kondo IO-J £2450
    For sale a Kondo IO-J.
    The cartridge has been checked out by Guy at Puresound and is playing perfectly. Guy fitted new flying leads.
    The cartridge comes with the original box.
    £2450
    I'm jagtar.
    Default Kondo IO-J Cartridge
    PM sent
    I'm Peter.
    This cart can be a revelation; with the right step up and tonearm. The cart usually has female pins on the end of its flying leads so you will need to make some pins to connect the two female ends (easy to do) or find the original KSL LP tonearm cable with its male pins and run it along your tonearm. alternatively , have a new set of flying leads made with male pins
    At this price it is a real investment and Kondo will rebuild it. Rarely seen and not well understood but in the right set up is wonderful. Mine is a keeper. GLWTS
    I'm Ritchie.
    Thanks Perart1
    The cartridge is provisionally sold
    I'm Ritchie.
    Bump. Actually still for sale!
    Quote Originally Posted by Frog-n-Oatcakes View Post
    There has been a change in the rules for sellers Richie. Now for any item with an asking price of more than £250, the advertisement must be accompanied with large full-size images of the actual item for sale. Thumbnail images are no longer sufficient. Since the new rules now apply after your original post was made, you would not necessarily be aware of them, so I'll enlarge the images for you:
    It might help your sale if you could provide some idea of the condition of the stylus and of how much use it has had. Good luck with the sale.
    I'm Ritchie.
    Thanks Barry.
    Guy checked out the stylus and diamond and they are both in great condition.
    I'm Ritchie.
    Bump.
    Reduced to £2150
