It's arrived!!! A day late due to Royal Mail technical issues (M6 crash causing huge delays)
More to follow
More to follow
Looks well suited mate, how are you liking it so far?
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I expected it to be a bit livelier than the Kontrapunkt b, but it's not coming across that way. It's kind of the same although the there is an openness which is a little eye opening. It's definitely a top level cartridge but I need to fine tune the setup. Im hoping to get a bit more authority and weight in the sound so checking the setup and just noticed the tail is a little down. Everything else is pretty much as close as can be gotten.
Glad you've got it up and running! Bit busy just now, but....*Before* arriving at any conclusions, put it in the MG-10 headshell I've provided, as I'm not a big fan of the ones with the rubber strips (which I see you've removed, lol).
Trust me, that will make a difference! Not sure whether you'll prefer it or not, but it *will* be different.
I tried that one first. I felt it was lacking bottom end, put this one on and the bottom end returned. Whether it's supposed to be there or not Is a completely different matter
Setup was perfect in that on too, just refined this ones setuo and it's singing nicely. I've got a third head shell to try too.
No worries, mate. Whatever works, works. Also, don't be afraid to track it right up to 1.5g, if you feel that the sound needs a little more 'solidity'. Plus, give it plenty of use because in reality the cartridge is probably hardly run in, as I was mostly using my 103s and SPU at the time, so it's virtually new!
Yep, track at the heavier end if you feel it’s a bit bass light.
Hunter S Thompson
I'll give the headshell another run out mate. I just know what to expect from the one I have. When I'm familiar with the cartridge I'll plum your headshell back in and see what happens
Tracking at 1.5g now and it's better balanced. Top end was a little high in the mix just. More natural now.
What I am noticing is how the sound is projecting into the room. It's also doing this this strange thing where I think I'm hearing things from the other room or from outside. I'm not, it's the track and nuances that are being collected in the track. It's a strange sensation.
Yesh, it's called resolution!
That's what the DL-S1 positively excels at: digging deep into recordings and unearthing/teasing out a wealth of detail that's in those grooves (familiar ones) you probably haven't heard before, and enveloping the subsequent musical delivery in a cavernously wide soundstage
It is cavernously wide. What I'm not getting yet is the depth. It's either unavailable or the cartridge is a more forward than the Ortofon in presentation.
The Setup is now as good as I can get it, which is spot on! Only thing to tweak is VTA. Currently it's perfect so I'm reluctant to mess too much plus it sounds very very good.
I'll give this a run for a couple of days and then put the Kb back in and see what's happening.
