Just done a major upgrade, plumbed in some Cambridge Audio Symphony speaker cable priced at a staggering £2.19 a metre!
Bluesound Node 2i
Audio Analogue Pucinni SE
B&W DM607 s2
Klotz ic’s
I'm Gary.
Solid core Cu is all you need. Why not take a trip to your local Wickes and buy the biggest cross section diameter copper cable they have. I used to use Nordost SPM speaker cables at stuipd pounds per meter. I then went onto Van dan Hul Blue 6mm Studio grade at far less cost and then 6mm solid copper from Wickes (no difference) in sound quality and cheaper than Van den Hul.
Nah you're allowed to include what you already have without adding to the cost.
I bought a Cambridge audio reference cable off ebay for £10 the other day. Chucked it in with some kit I already had. It sounded amazing. You'd literally think it cost thousands. All for a tenner!!! (Plus a few bits I had before.)
I'm Gary.
Me too, I got a pair of Cambridge Audio Studio Reference cables on Ebay for £20, some poor sucker paid £120 new.
To me they sounded exactly the same as my Cambridge Audio Pacific ones which in turn sounded the same as the Chord Indigos I borrowed.
I'm sure the devout will say my equipment isn't good enough to exploit the better cables or it's my hearing or something similar.
I won't convince them and until I do actually hear a difference they won't convince me either lol
Marantz CD63 KI Signature
Project Debut II
Pioneer A656 Reference
Epos M5s
Atacama Stands
Maplin speaker cable cos I can't hear a difference
Various interconnects as above
The use of twin and earth cable used for permanent mains wiring as speaker cable was all the rage in the '80s.
I don't like solid core cables as I believe cables should be as flexible as possible. Actually I don't like (unbalanced) cables at all: so use monoblock power amplifiers located directly behind each speaker and run balanced line cables back to the preamp. That way my speaker cables can be as short as 30cm.
But I agree with you - there really is no need to spend a lot on decent speaker cables. Or for that matter on interconnects.
I'm gone.
Coo. This has turned into a proppa cable sceptic thread.
Well, I love my foo speaker cables and I think they sound great!
'SPECIALIST EXTREME HIGH END AMAZING!!!!' (from the link)
Coorrr, wow.
I'm gone.
I have to confess that the outrageous hyperbolic blurb was what attracted me to try them.
And, amazingly, expectation bias led me to actually agree with the hype.
They really are very good.
They are made by W&M, a well established Dutch company. Very well made. I also have a pair of balanced interconnects made by them which could be used to tow quite a large ocean going liner!
