Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Hi-Cap DR - For Supernait 2 - Damn It !
  1. #21
    I'm Phil.
    beautiful amp , get one sometime .
    Eric Bibb
  2. #22
    I'm Shane.
    Quote Originally Posted by hifinutt View Post
    Might get one in the next year or two. I've had a few Nait 5i's and quite liked them.
    S.
    Shane Lonergan.
  3. #23
    Quote Originally Posted by southall-1998_mk2 View Post
    How are you getting on with the SN2, Bev?
    I sometimes get thoughts of owning one someday.
    S.
    I love it Shane.... and the Hi-Cap DR does add 'something'...
    I will remove the Hi-Cap from the SN2 in the future just to see whether I prefer the SN2 by itself or not but I'm in no rush at all as I love both together at the moment
    I can highly recommend the SN2 Shane. In my experience it sounds absolutely nothing like 'Naim of old'. It took me about 20+ years to like anything Naim, amp wise
    On a side note..... I thought you were 'off' AoS
    Bev
  4. #24
    I'm Shane.
    Thanks, Bev.
    How does the SN2 compare to the XS-2? (You owned prior)
    S.
    Shane Lonergan.
  5. #25
    Thanks, Bev.
    S.
    The XS-2 is a fantastic sounding amp Shane and if it's within your budget you will not be disappointed and I don't think you will better it for the outlay
    I owned the XS-2 at the same time as the SN2 and had a hard time deciding between them
    In the end the SN2 just sounded a bit more 'grown-up' if that makes sense
    However for about £1K used you simply have to try an XS-2
    A used SN2 is about twice the price of a used XS-2 and I don't think the SN2 is twice the amp
    Luckily I kept the SN2 which was probably wise for the little extra power I now need for the Maggies but the XS-2 is a terrific amp for the money
    The XS-2 is an amazingly musical sounding amp and if you have only owned 5i's you will be amazed by the XS-2
    Get an XS-2 Shane you will not reget it...
    If you have the extra funds for a SN2 you won't regret that either...
    Hope that helps Shane..
    Bev
  6. #26
    I'm Shane.
    Thanks again, Bev.
    Gulliford Hi-Fi in Exeter stocks both the XS-2 & SN2. Must pop down there for a listen sometime next year.
    S.
    Shane Lonergan.
  7. #27
    Thanks again, Bev.
    S.
    No problem Shane
    Just buy a used XS-2 and see how you get on but if you have the funds buy a used SN2 you won't regret that either
    Bev
