Should it look anything like the bezel on this Neutric jack socket?
https://www.ebay.co.uk/itm/REAN-Neut...53.m1438.l2649
I’ve just been looking on there too and found plenty of the nut type 6.5mm ones but I think it should be a gnarled type or a plain chrome ring , I know it doesn’t make a lot of difference but my ocd won’t allow me to fit the wrong type ( coz I’m nuts )
I'm Paul.
Sounds like it could be a dry joint or broken connection. You can poke the insides with a wooden dowel while the amp is on and plugged into the system. If there is a bad joint and you find it with the dowel you’ll hear it through the speakers.
I might have a plastic bezel for a 6.35mm socket I can send you, if I can find it?
~Paul~
I'm nigel.
Is there a capacitor fitted across the power switch?
I understand these are used to reduce arcing inside the switch.
I've had vintage kit in the past where this cap burns out after prolonged storage....there may be a crack and small puff of smoke causing one to kill the power in a panic. Then when you power back up.....no perceived fault
Worth a check.
I'm Allen.
Lets hope it stays that way for you Andy
