Hi guys,
I am looking to clean and lubricate the promote motor on my recently acquired Rega P25.
I have watched a video on you tube and he sprays electronic cleaning spray into the motor at both ends to help clean it and dissolve muck before lubricating.
I have been scanning the net looking at different forums and there seems to be differing opinions, with deoxit the main choice in the USA.
In the U.K. deoxit has to be imported which makes iti very expensive. From what I can read it’s good beacuase it leaves a lubricant afterwards, where as some cleaners don’t and can cause scratchy pots etc a few months down the line.
I have been looking on Amazon and come across the following cleaners
DP-60 Electronic contact cleaner degreaser
WD-40 Fast drying contact cleaner
Servisol Super 10 Switch contact cleaner
Ambersill PCC cleaner
There was even a spray can which was pretty much isopropyl which 8 have a bottle off.
Any advice or experience of using any of these would be much appreciated
Thanks
