Results 11 to 20 of 33
Thread: OTL
    Lol aye, be nearly half the cost of the amps!
    I figured it might be something like that Ali. Mind you, there are some monster prices for 300B's.
    I'm Peter.
    Cheers Peter, looking forward to getting these built.
    Ali, Doesn’t the best deserve the BEST how about Shuguang 300B-T Tubes (Black Tulip) only Ł282 matched pair. Lol.
    It would look very sexy on or off!!
    I'm inthescottishmafia.
    Lol maybe, but would get a bit pricey buying eight!
    From reading the Transcendent forum JJ’s seem to be the best choice. Can’t use mesh plates.
    Hunter S Thompson
    Aye you’re not wrong.
    Hunter S Thompson
    I'm Clive.
    At least mesh plates are banned from Pinnacle so that's some cash saved! It should be possible to do a deal on 8 JJs. If I go ahead too maybe it could be 16JJs to entice a good deal.
    Sounds like a plan Clive, PM if you have a good source.
    Hunter S Thompson
    Over the years I have been intrigued by OTL designs, but being uneducated I felt that electronic failures could result in more easy damage to speakers ( no transformers to act as a cushion). Have I got this wrong?
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    In this case yes. The Mini Beast I’m using at the moment has caps on the output that will prevent DC reaching the speakers, and each channel is fused in case of a short in a valve. I’ve hunted the Transcendent forum and can’t find a single instance of speaker damage caused by amp failure, and Bruce has been selling these types of amps for many years.
    Hunter S Thompson
    Sounds good Ali
    Source
    SW1X USB II
    Amps
    Speakers
    Cabling
    Headphones
    Yes, seem very reliable to me, I’ve been using my Mini Beast for a couple of years or more, for the last year it’s used several hours a day as I run the telly through it as well. It’s never put a foot wrong apart from once blowing it’s mains fuse due to my mains running at over 250v(!). Switch on surge I guess. Replaced the fuse with a slightly higher value and it’s been fine since.
    Hunter S Thompson
