It supports both Tidal and Qobuz via Upnp or Airplay plus it also supports Spotify connect. I use the mconnect ap on my ipad to listen to Qobuz via moode.
I'm Luke.
I haven't updated in a year or so - any SQ upgrade, or just new toys to play with?!
I'm Paul.
I'm Mel.
I honestly can't hear any SQ difference between Moode and Volumio.
I have 2 identical (3) pi's and 2 Allo (Piano) DACs's so can do side by side comparison's.
I just keep the standard settings and find the sound of both Moode and Volumio is fine for me.
My initial preference was for Moode because I found Volumio so buggy but since using the recent versions for a couple of months I now find the whole look and feel of the UI app so much better with Volumio and the bugs seem to have been fixed.
After listening to and using Moode 4.3 I am not going to move away from Volumio - for me SQ for both is fine for me and the user satisfaction/interface is better with Volumio for what I am looking for.
Mel
I'm Paul.
I'm Luke.
I've just bought an allo digione and was wondering what player to use. Was set on Volumio but if the latest version Moode is good I may have to get this on a 2nd SD card and switch between the two.
Am I right in thinking that Spotify and Tidal are now also integrated with Volumio?
Sent from my SM-G930F using Tapatalk
Current system:
RPi + Allo Digione
Beresford Caiman Seg & Dorado powered by 15v Linear PSU
Transcendent Sound Mini Beast OTL
Amptastic Mini-1
Klipsch KG4.5 Speakers with Titanium Diagphrams and Sonicap Cap upgrade
110aH Leisure Battery powers the Mini-1 & Digione
