Results 21 to 30 of 33
Thread: Best £20 I've spent on HiFi
  1. #21
    I'm Adrian.
    Quote Originally Posted by Oddball View Post
    Interesting bit about your DIY record cleaning there Aidrian
    I have the Knosti stuff ,but it really pisses me off doing all that faffing with 2 baths and trying to keep my labels dry . The dam solution creeps into the label a bit (despite me trying to mod the seals ) and even after they drain ,as you say , seem to get that bit of a trail of stuff , despite me rinsing time and again .
    I have a really old early electric turntable that is scrap , so I might try your method
    Why not have a go its not hard, and the results are pretty good IMO, all you need is a cheap wet/dry vacuum, some duct tape to blank of the end of the hoover attachment and some glue to fix the velvet ribbon. I used a carefully held curved flooring stanley knife to cut the slit (be very careful it does not slip), the slit only needs to be about 2-3mm wide.
    Order some 99.9% Isopoyl Alcohol, get some Distilled water, and some bottles, these are great https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1, some ILFORD ILFOTOL WETTING AGENT https://www.ebay.co.uk/itm/VINYL-REC...oAAOSw8d5ZS-LT mix up some cleaning fluid to the correct mix and off you go (I have found about 30% Isopropyl to Distilled Water works well. In 500ml of cleaning solution you only need 2.5ml of the Ilford wetting agent, it is important as it breaks the surface tension of the fluid and allows it to enter the grooves and free the dirt, and for it to be removed easier with the hoover. The brush to gently hold on the record and spread the fluid is one of these cut into 3 https://www.ebay.co.uk/itm/Paint-Pad...UAAOSwv0tVJBE2, after cutting make sure that you use a small clean brush to get rid of any small bits of plastic before using and keep fingers off the pad head, regularly hoover it off between cleaning, when it starts to discolour throw it away and start with a new one.
    Hoovering will get about 99% of the cleaning fluid off so any residual gently remove by wiping around the record with one of these https://www.amazon.co.uk/Extra-Large...ds=micro+cloth and change them regularly as they will get dirty. If you wash them out then rinse them in distilled water, no soap products and leave to dry naturally.
    In extreme case I have found that some really dirty records can take 3-5 cleans, if a record is obviously dusty and dirty then I will clean it first using a mix of L'Art Du Son first https://www.amazon.co.uk/s/ref=nb_sb...=1ED0A3N2O5B4D and then rinsing with distilled water, and then clean with the above cleaning solution. I suspect that the L'Art Du Son has some form of detergent in it that helps remove tobacco smoke residue and grease, I keep separate brush pads and microfibre for use with this solution. Some people don't like L'Art Du Son but it seems to be a very effective cleaner IMO, but make sure you rinse the record after to not leave any residue behind.
    Remember if you are disappointed after your first clean of a record do not give up on it, it may take several cleans before it gets really good. Even though it looks clean you can still have dirt left in the grooves causing crackles. Having said that if the record has marks/scratches across it and you can feel these with you finger tip then these may be the issue. But you'd be surprised, I have some records that if you looked at them you would say that they will sound bad because of the marks on them, but when played they actually pretty quiet. I know some people advocate cleaning a record before playing because they believe it immediately becomes contaminated once out the sleeve. Personally I think this is a bit extreme, but I do think that cleaning after 15-20 plays is worth doing. After cleaning pop into a new sleeve liner like this https://www.ebay.co.uk/itm/50-12-POL...sAAMXQd2hRYVdL
    Have Fun.
  2. #22
    I'm Tim.
    A turntable needs inertia and isolation. The amp needs isolation. The speakers need inertia. One can ancor the speakers with stone or pavement on top for none or little money to fantastic result.
    I have put sorbothane feet under my Thorens TD14x & TD16x heavily tweaked that is now super heavy with chunks of marble casted in it's base to weight enough and reach the required inertia.
    The sorbothane feet do not bounce one bit and are there to isolate the plinth from it's support. I have made some sort of light plywood platter onto which sits my amp that work as isolation already.
    And yes, since I also did find some improvement like even better focus "image" after having set that "isolation" platter. Now I am tempted to add little pieces of sorbothane beneath it's pike's feet discs.
    Thanks for sharing that and giving me the thought to improve for little money and easy adjustments my phono setting without hassle. Would the external preamp benefit from such isolation as well ?
    - Cart Denon DL-102 in bakelite Ortofon SPU 'G' type headshell
    - TA SME 3009 'Improved' converted in heavy mass with detachable headshell
    - TT Thorens TD160 'E' totally tweaked driven by an 'Eagle & RoadRunner' PSU & tachometer combo
    - Matts top to bottom: leather, cork, felt & 12" vinyl
    - Pre-amp 'Modulis' Isem
    - Amp 'Exampli' Etalon 2x40W
    - Speakers 12" Leak 'Sandwich' first generation creatively recapped
  3. #23
    I'm John.
    Would it be possible to post a few images of your DIY TT Cleaning system, with the modified head attachment, sounds like a good addition to a cleaning set up.
    I'm starting to view the subject of Isolation as more of a Subject of Attenuation.
    It seems to me that the end result is a control of the frequencies that influence the presentation.
    So the acceptance of certain frequencies being perceived during a replay, will be subjective across different listeners, a attractor for one will be another's detractor to the produced sound.
    Trialing and comparing different materials and set ups is key to finding the attenuation that is a attractor to the intended listener.
  4. #24
    I'm Gary.
    ebay link to the sorbothane pads please?
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  5. #25
    I'm Tim.
    The seller with some of the best prices and widest choice I have find on the eVilBay in UK is called 'dappletoft'. Hope that suffice...
  6. #26
    I'm Neil.
    Default Best £20 I've spent on HiFi
    Sorbothane needs to be loaded properly to work as it should.
    Take a look at: https://www.qtasystems.co.uk/article...emispheres.htm for some loading charts.
  7. #27
    I'm Adrian.
    Link for Sorbothane pads https://www.ebay.co.uk/itm/4-x-SORBO...72.m2749.l2649
    Regards
    Adrian
  8. #28
    I'm Anto.
    Have Fun.
    Thanks for that Aidey !!
    You have urged me on to get my Knosti baths out for the afternoon . Rooting out an old lp case that sat in an unheated room for a while and all the records have a degree of mould in patches on them !!
    I have to kitchen to myself ,lots of hot water (not too hot !!) and a dilute fairy liquid in a squeezy bottle.
    Into the one under the warm tap a good squeeze of fairy then in with the water , in goes the lp and several scrubs 360 ,back and 2 for a minute maybe then rinse off suds under the cold tap , then straight into the other bath with my 30% IPA , distilled water and a squirt of rinse aid .
    Spin the excess off by hand ,out of clamp ,and into the drying rack on the clothes drier over the Rayburn,
    Once I have 6 in rack , and they are dry ,I tranfer to a secondary rack to dry completely , while doing 6 more .
    Lay the first one or 2 and I am satisfied . A couple of cruddy noist ELO albums sound very quiet considering the mess they looked
    I will look into your idea . I did make a wand once and adapted the wifes hoover ,but what a fag
    Maybe time to do it again
  9. #29
    I'm Drew.
    Choosing the correct load type appears rather problematic with equipment of uneven weight spread, for example, valve amps sporting trannies at the rear. I'd estimate my power amp is circa 30kg with most weight concentrated at the rear. Going a size or 2 down for the front support isn't an option as the height of the sorbothane supports are different the lower the load they are intended to support...
  10. #30
    I'm John.
    I've just had a view of Adrian's record vacuum cleaner and it looks very powerful, I imagine it could levitate the record from the platter.
    I don't think any 'pesky varmint' particles will escape it.
    A clever little bit of improvisation.
    I think this will be better than the second hand Airblade hand dryer I was toying with the idea of buying.
