Results 1 to 2 of 2
Thread: Project speed box SE for Thorens TD160
    I'm Phil.
    Default Project speed box SE for Thorens TD160
    Hi all,
    I have the oppurtunity to buy a Project speed box SE for my Thorens TD160 which has speed change issues. From a little bit of research i understand that this combo works, but as i have a hard wired version rather than kettle lead can anyone explain how this works?
    Thanks,
    Phil
    I'm Tim.
    The speed changes issues you have can easily be corrected if ever. On the other hand if you go for a speed box, you'll gain some on speed accuracy as well. Don't have one, but I guess it's a "plug and play" device. But I have a Phoenix Eng. PSU & tachometer combo that shouldn't be much harder to install.
    - Cart Denon DL-102 in bakelite Ortofon SPU 'G' type headshell
    - TA SME 3009 'Improved' converted in heavy mass with detachable headshell
    - TT Thorens TD160 'E' totally tweaked driven by an 'Eagle & RoadRunner' PSU & tachometer combo
    - Matts top to bottom: leather, cork, felt & 12" vinyl
    - Pre-amp 'Modulis' Isem
    - Amp 'Exampli' Etalon 2x40W
    - Speakers 12" Leak 'Sandwich' first generation creatively recapped
