Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Hot new audio foo?
    I'm tony.
    I have been disk rewinding for a number of years utilising a static bike in the cellar.
    One disk takes about 20 minutes at full pelt.
    I have found green electrical tape for attaching to the wheel the best solution so far.
    After treatment the colours are far more vibrant although i would recommend about an hours rest for the wheezing to subside.
    Your solution is far more advanced....i commend you!!
    I'm Tony.
    This is great news, as a solution to the problem of 'bit slide' has been long overdue!
    You may need to put some consideration into our Antipodean Audiophiles as far as the equatorial mount is concerned though, casual alignment with Polaris is not going to work for them?
    Tony
    I'm tony.
    pulsar positioning is the way ahead...gps is dead
    I'm Stewart.
    Mmmmmmm.Sounds like spin to me.
