Results 1 to 5 of 5
Thread: WTD Knosti Disco Antistatic Generation II Record Cleaning Machine
    I'm Drew.
    Default WTD Knosti Disco Antistatic Generation II Record Cleaning Machine
    Hi
    Looking for the above WITHOUT cleaning fluid. Thanks!
    I'm Patrick.
    Was thinking of getting one these myself, anyone got experience of using it? I don't have enough records to justify buying something more expensive.
    I'm Mark.
    I have one of these and a Moth machine. As far as cleaning is concerned I think the Knosti is as good if not better than the Moth, the only thing is the Knosti doesn't dry/vacuum the records so you have to wait for them to dry naturally and I find this messy and awkward. I sometimes use the Knosti to wash and the Moth just to vacuum.
    I'm Gary.
    I have one of these works perfectly, I don't find the process messy. They come with a drying rack that holds about 12 records. In my study the records dry in about an hour.
    I'm Patrick.
    Cheers, think I will go for it.
