Sadly I only rescued the one .
It weighs a ton !
It weighs a ton !
I thought you'd know that by now! Early B139 so probably a K2 Celeste if that's a T15. There were also one or two really early speakers, might say on the Kef Museum.
Probably from a kit. Mind you the crossover is.a.bit more complex than I expected.
Same configuration as Celeste and Concord, but doesn't look like a KEF box. Other makers bought these drivers in for their own speakers.
Looks to be what Kef call “ K2 Baffle “ hence the unknown cabinet
Interesting that the impedance is marked 12-16 ohms. I don't recall KEF making the B139 in anything other than 8 ohm impedance. Could have been a special order for some maker.
Pretty bloody useless really unless someone needs a white surround B139
Could use it as a sub.
