Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 87
Thread: Cabinet Plans for Tannoy HPD 385
  1. #41
    I'm John.
    Quote Originally Posted by cooky View Post
    Looking good, I'd front mount the driver John.
    Thanks Frank and thanks for your help.
    Will try front mounting, no gasket at the minute.
    I take it it will sound different?
  2. #42
    I'm John.
    Not sure if this link will work....especially for Macca, some Diana Krall.
    https://imgur.com/ch6EYbO
  3. #43
    I'm Richard.
    You may wish to staple a piece of cloth over the rear of the port to contain the rockwool particles that may become airborne as air flows out of the port.
    Main System: Mac Mini > Schiit Yggdrasil 2 OG > Yamaha A-S3000 > Celestion Ditton 66
    Headphone System: Mac Mini > Schiit Yggdrasil 2 OG > Sparkos Aries / Schiit Mjolnir 2 > Sennheiser HD600
  4. #44
    I'm John.
    Quote Originally Posted by ToTo Man View Post
    The thought of all that glass fibre open to the room had crossed my mind, not good.
    I hadn’t thought of putting a piece of something over the end of the port.
    As these are very much prototypes and won’t around for too long, I hope, I think I’ll stick with it as is for now.
    I’ll try blanking the port by 1/3rd then 2/3rds and see how it goes for bass response then perhaps lengthen it.
    Sorry I didn’t fit 3 x 100mm circular ports.
  5. #45
    Just use some grill cloth.. Bass will go right through it ok.. you can fit it on inside so its not seen
    I'm Dennis.
    ATC used fish net, I changed the mesh used in wedding veils.
  7. #47
    I'm John.
    Good ideas fellas, thanks. Still messing with port dimensions. All compromises!
  8. #48
    Quote Originally Posted by JohnJo View Post
  9. #49
    bass is quite tight
    I'm frank.
    Hairspray is your friend.
