Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 77
Thread: HF Hearing Loss
  1. #61
    I think your post highlights that we don't all have 20-20 Khz hearing. I am fortunate in that my hearing is holding up pretty well as I age (better than the rest of me). Having less than perfect hearing does not necessarily reduce our listening pleasure, though it may influence our choice of hardware. Many people are cynical over full range driver speakers since many such drivers have a HF roll off above 15 Khz or even lower. However, if your HF hearing is reduced, does this matter.
    I think many people do not have a sense about what a high frequency note sounds like. I am sure that many people would be absolutely shocked as to how high a 10 Khz tone sounds like.
    Geoff
    Hence my post (#54):
    @pygmypony
    I downloaded the nch tone generator some years back, and in my setup it was full of similar glitches to those you are reporting. An oscilloscope confirmed what I feared: rubbish software. And no response to my emails from the developer.
    No such horrors from an old analogue signal generator.
  3. #63
    It's all quite baffling. What Barry says makes perfect sense to me, and I've been aware of harmonics for a long, long time. Goes back to when I used to go on ride-outs with a friend, and when our bikes were running at a certain point in their rev ranges, a third note could be heard. Then if one of us accelerated or braked, the note would disappear.
    Why then would manufacturers of full-range speakers not be all over this? Surely they would be aware of this. maybe they think that losing these harmonics is compensated by having the advantages of a single driver, whatever that is. (technical bods, feel free to weigh in here).
    My own speakers each have two full-range units, complemented by a tweeter that runs from 10kHz to 25kHz (I'm told) so I should be ok.
  4. #64
    I'm manny.
    Don't worry about it . If your above 55 it's completely normal . With age our HF hearing diminshes . I can hear to 14 k cycles and I could swear I'm hearing as I always have . Above 14 k all we have mostly are harmonics and even then most of the upper range of harmonics are lower the 14k cycles . If you can still hear a bright recording sounding bright your ok .
    As a matter of fact my wife is 59 and can only hear to 8 k and even then she can hear subtle differences in the sound of my system when changing components
  5. #65
    dont know how far up and down my full range ones go but its pretty good. i did have a graph once but seem to have lost it for now... supposedly pretty flat from 35 to 15k. certainly sound good.
    similar to these i guess... except ive got 2 in each box... https://www.ebay.co.uk/itm/Pair-Tele...QAAOSw~7BamZQl
    Interesting as it all is, at the end of the day it's all numbers, and I doubt that missing the highest frequencies is a real barrier to our musical enjoyment. Apart from my rather dull sounding Pink Floyd remasters, which I posted about elsewhere, everything sounds fine to me. Even though bats can hear extremely high frequencies, I certainly don't envy them. And definitely not their diet which is mothy in the extreme.
  7. #67
    I'm Dennis.
    My right ear now only goes to 5K, due to BTs insistence on my using a headphone which produced up to 131.5dB, this necessary when trying to identify bleeps in a noisy environment of 105dB.
    Anyway I bought my Betas with the litigation money.
    The brain adapts its software to what the transducers are doing, and the real musical info is centred around 1K, maximum intelligibility vocally and I think musically being commercial speech bandwidth; 300 - 3400Hz. Mostly above is 'sharpness'.
  8. #68
    I'm nigel.
    Davy Crockett was deaf in his wild front ear
    James T Kirk was also deaf in his final front ear.
    These jokes Grade II listed.
    Thank you.
  9. #69
    Three AOS members:
    "Isn't it windy?"
    "No, I think it's Thursday."
    "So am I, let's have a cup of tea."
  10. #70
    'Doctor, I seem to be having some difficulty hearing properly' 'Can you describe the symptoms ?' , the doctor asked. 'Homer's the fat bald bloke and Marge has blue hair'. (yeah, I know; rubbish, but it's late !)
