Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Tapped Horns
    I'm Rob.
    Default Tapped Horns
    Hi
    got a pair of tapped horns I built from 22mm black valchromat using the design from -
    http://wp.volvotreter.de/projects/th...eminence-horn/
    using Eminence KappaLite 3015LF drivers
    height 2300mm-depth 495mm-width 495mm
    The valchromat is natural at the moment I will be finishing with danish oil when I get them out for a sale
    All jointing done with a Festool Domino joiner and all joints sealed so nice and airtight through the horn
    Have a MC2 T1000 to drive 'em if required
    £1300 for the horns
    £450 for the T1000
    Location: Bristol, since 1978. Current house since 1996!
    A few folk thinking.....marriage....or speaker? (-:
    Great things!
    Chris.
    I'm Rob.
    They'd be perfect for those Ocellia's Chris you still got 'em ?
    £500 worth of valchromat and £400 for the drivers ...bit a bargain should be a grand each
    I'm Jack.
    Default Corners
    Great work Rob.
    A prospective purchaser might be wondering if they will go in corners, given their size. (I notice they are pictured alongside the main stack.)
    The ones that Speedysteve built (also using Eminence drivers) certainly were fine in corners. Steve was using digital active crossovers which would have had time alignment capabilities.
    Jack (who once transported a pair of subs (different design) for you from Soton to nr Oxford - remember?)
    I'm Rob.
    Hi Jack yeah remeber ,you started me on the sub route with that 18" box I bought off you and I certainly enjoyed the Lab12's that I think ended up at Haywards place .
    Currently have them flat against the back wall firing straight out with one horn in the corner...worked well .
    I'm Rob.
    bump
    I'm Rob.
    bump - sensible offers considered
    I'm Rob.
    £1000 for the horns
    £450 for the MC2 T1000
    Is that a hamster run next to the speakers?
    I'm Rob.
    Stll for sale
    £600 for the horns
    £425 for the MC2 T1000 could post at cost or pickup meet Southampton M3
