Results 1 to 10 of 11
Thread: 3 second remedy for loose valve bases
    I'm Drew.
    Default 3 second remedy for loose valve bases
    A simple yet effective solution for valve bases that feel slightly loose, avoiding crappy, messy gluing...Gently slide the pointed end of a wooden tooth pick between base and side of the glass then carefully bend back to snap toothpick off the at the tip. Repeat on other side if necessary. Works a treat...
    I'm Gareth.
    An alternative option: Inject a small quantity of nail polish remover between the base and the glass all the way round. This seems to reactivate the original bonding material and attaches the two together again. Worked for me with a number of loose bases.
    I'm Dominic.
    Back in my TV repair days we used to get some needle nosed pliers and put a small kink in the valve pins of only a millimetre or so which worked every time. The valves then would be as firm as a rock and a quick wiggle cleaned crud off the valve pins too. Helped cut down microphony as a bonus.
    CD player = Marantz CD6006
    DAC/pre = Rotel RC 1572
    Power amp = ADA PF201
    Speaks = Quadral Chromium Style 6
    we moved to transisters
    I'm Justin.
    Big mistake. Huge...
    valve tvs were troublesome ...
    I'm Justin.
    Heard that.
    Valve CPUs were also quite large
    I'm Drew.
    Like that too!
    Quote Originally Posted by Getgaff View Post
    I'm Ian.
    John turrell, rip, a valve guru I used to know always recommended superglue to me
    Quote Originally Posted by Mr.Ian View Post
    That's what Ask Jan in Germany recommended to me.
