its what the hole in your records are for oliver
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I'm mark.
I've just put mains lamp on the strobe markings, and its way off stable. Is it generating its own (independent) flash for the platter?
Mines 100v, but still running off 50hz
I'm John.
The Independent Strobe Light in the Link, is close to Half the price of the Keystrobe.
If it is suitable it will be a few ££'s saved.
https://www.ebay.co.uk/itm/LP-Record...IAAOSwQOxdTSpp
I'm mark.
Thanks John, its in my watch list. Would be useful to see if the Sony's operating at 60hz.
I meant to PM and appologise for missing you the other day, will catch up one day ...
I'm Deleted.
As far as I’m concerned there is only one way of defining turntable speed consistency and that is by using the algorithm Paul R (Ruggles) of pfm offers (has designed). This was capable of showing the cogging of the recording lathe in the test record used when I measured my own deck and is far beyond simple wow and flutter measurement.
Account Deleted
I'm mark.
Background, I'm considering buying Keystrobe for my Garrard 301 (independent frequency locked light source), I normally use mains powered lamp to read the strobe on the platter, its near enough for my clothears.
As the Sony is next to the Garrard, I shone the light on the platter to find the markings running fast on the mains lamp, but rock solid off the inbuilt light.
I was wondering if the Sony had its own frequency generator for the strobe?
Off to put Garrard platter on Sony
Edit, Sony and Garrard platters aren't synchronised
I use the strobe lamp and checked too. 33.3!
Sent from my SM-G930F using Tapatalk
Main system: Sony TTS8000; AT1010; Audio Technica Art1; The Lentek; Cambridge 851n, Yamaha NS1000.
System 2 - SBT; Technics SH-X1000 DAC; Denon PMA-850
I'm John.
Hi Mark
I have a TTS under the knife as you know, when it is done, if you wish, we can cross paths and you can give it a audition.
I can pass on the Phonotherm as well.
I'm very domestically busy at present, so it will be in the New Year hopefully before Easter.
today i started!
1st thing to make was a veneer press to get the plinth top veneer nice and flat and to glue up the side layers of mu25 ply.
My System
John Wood KT88 Amp.
