Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Vintage ECC83/12AX7 and 5751 valves
    I'm Drew.
    Default Vintage ECC83/12AX7 and 5751 valves
    Hi Guys
    Some top notch signal valves for sale. All are fully tested using calibrated AVO 160ct and test as new or- in most cases- higher unless stated (exact values available upon request). These are mainly rare vintage and certainly not cheap but are priced to sell, significantly lower than can be found on the usual online sites...
    Sylvania 5751 3 mica MATCHED pair £85 delivered SOLD
    Telefunken ECC83 <> ribbed plates, MATCHED PAIR £125 SOLD (more available on request)
    Tungsram ECC83 Foil Getters, welded plates, M7 date codes, MATCHED PAIR hen's teeth rare and perhaps the best ECC83 ever made £225
    Philips ECC83 'dimpled getters' MATCHED pair £70
    Mazda 12AX7 ECC83 chrome/silver plate MATCHED pair £125 delivered
    Tung Sol 12AX7 1950's 'D' getter long plate £80
    Brimar CV4004 12AX7/ECC83 £125 MATCHED pair delivered
    Tung Sol 5751 long plate 'D" getters £80 pair delivered
    Siemens ECC83 long plate £95
    Lots of ECC83 porn I started tube rolling the for my EAR 834 clone, shame your advertising pairs as I'd need three .
    PRE
    I'm Drew.
    3 may well be doable for most...Let me know which ones you're interested in :-)
    I'm Drew.
    TFKS SOLD
    can I have the Sylvania 5751 please
    PM me your PP address
    Lumley Heliosphere Audiomods 5
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
    Magnum Dynalab Etude, RWA Cassabria + LCD 3
    Wilson Benesch Actors
    I'm Dominic.
    Let me know if you have more TFKs
    I'm Drew.
    no problem Martin, thanks
    I'm Drew.
    Sylvania 5751 SOLD, thanks
    I'm Drew.
    bump....some great tubes still left
    I'm Allthatwasisorwillbe.
    Hi Drew, i'll take the Brimar's off you
    Darren
    KORUS CUSTOM SERVER
    TECHNICS 1200 MKII_JELCO 750D_SHURE SC35C (with NOS and NEO SAS styli)
    CAIMAN SEG + DORADO PSU
    CROFT MEGA MICRO
    PARADIGM REFERENCE ACTIVE/40'S
    PARADIGM SERVO 15 SUBWOOFER X 2
    ''The theory of relativity is a mass of error and deceptive ideas violently opposed to the teachings of great men of science of the past and even to common sense''
