Results 1 to 10 of 20
Thread: New phonostage - which to go for?
    I'm Philip.
    Default New phonostage - which to go for?
    Hi,
    I’m looking for a phono stage, new or used, up to £200.
    Any reccomendations?
    Thanks
    I'm Andy.
    MM, MC or both?
    I'm Philip.
    Quote Originally Posted by Scooby View Post
    MM, MC or both?
    Mm needed.
    I'm Philip.
    MM, MC or both?
    Mm needed.
    I'm Phil.
    I can personally recommend this - you can normally pick them up for less than £200 used...fantastic piece of gear:
    https://www.ebay.co.uk/itm/Graham-Sl...0AAOSw-cFbknYS
    Schiit mani is good value if wanting mm. Does mc too but it's mm is a good one for money. Not sure what they cost new now but well under budget
    I'm Brook.
    You might be lucky & find a Kinshaw Perception SA two box phono stage for £200. Solid state, MM & MC, sounds bloody lovely, is very adaptable, more like a £500 plus stage & gets very close to more expensive stuff, I recently sold my very expensive Art Audio Vinyl One & the replacement was a choice between the Kinshaw or a Welborne Labs MM & a pair of Partridge SUT's, which was three times the price. I went with the Welborne but it wasn't three times better by any stretch, just suited my valve based system more I felt.
    I'm steve.
    I’ve owned both the Schiit Mani and the Graham Slee Gramamp 2, both are very good phono stages, of the two the Mani was definitely superior, I would still have the Mani now if I’d stayed with MM, only downside to the Mani is on Moving coil because load impedance is too low (47ohms) to be a good match for most cartridges, making them sound dull.
    I currently have a Cambridge CP2 which works equally well on MM and MC and I rate it as good as the Mani and GA2 and it’s considerably cheaper.
    The Mani can hum with some decks and not sure if it's due to location or hum-loops (rega arms in some cases but not others for some reason).
    Apologies for seeming to flog a dead horse again, but the Rega Fono seems good for MM types if the OP wants to buy new.
    Edwards Audio Apprentice MM
    Well under budget and I still have mine (after 10 years) for back-up duties. Has only been superseded by stages 5 fold of its price.
    Also the most unassuming little package.
