Due to a change in my system, and now concentrating on CD & Streaming I have for sale
ZYX R50 Bloom 3 H cartridge fully boxed with all bits.
It has only had 6.5 hours on it (i kept exact time records)
High output version.
Fantastic sounding cartridge and a bargin for someone.
New cost £850
Asking price £550 inc delivery.
Specs and images below
Type Moving Coil (Dynamic)
“REAL STEREO” Generator System
Cryogenic Treatment Temperature: -196 ℃ (-320оF)
Output Voltage 0.48mV (3.54cm/sec, 1kHz)
Frequency Response
±1dB 10 Hz - 100 kHz
20 Hz - 20 kHz
Channel Separation > 30dB 〔 1kHz 〕
Channel Balance < 0.5dB 〔 1kHz 〕
Recommended Tracking Force 2.0gm 〔 20 ゜C-25 ゜C 〕
Tracking Force Range 1.7gm - 2.5gm
Trackability >60μm /2.0gm
EQ Compliance horizontal
vertical
15×10-6cm/dyne
12×10-6cm/dyne
Internal Impedance 4.0 Ω (8.0 Ω)
Load Impedance > 100Ω
Coil Wire 6N OFCφ0.035mm
Cantilever Material Black ALMg5 tube φ0.45×φ0.30mm
Stylus Line-contact Solid Diamond □0.1mm
Contact Radius, Life Time 6μm×35μm, 2000Hour/2.0gm
Output Terminals φ1.25mm gold plated〔EIA〕
Terminal Board Glass Epoxy Plate
Dimensions 16.2mm(W)×19.7mm(L)×x17.6mm(H)
Net Weight 5.0gm, 7.7gm(TB), 9.5gm(SB)
