Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: new speaker cable
    I'm Gary.
    Quote Originally Posted by fazerman45 View Post
    my budget is around £15 a mtr,ive tried some second hand van den hul cs122 but not sure on it
    Try this
    https://www.audiovisualonline.co.uk/...cable-2-x-4mm/
    Gary
    Bigman80 Guest
    Yes, I use this. It's good stuff.
    I'm Gary.
    I pinched the idea off Oli, buy unterminated and use Z plugs
    Gary
    Bigman80 Guest
    Gary
    Ha, glad to have been of service again, Gary.
    Yes, Z plugs, bit of heat shrink and you have a nicely terminated cable.
    I'm steve.
    If you like your Chord interconnects why not try Chord speaker cable. You don’t state whether you single wire or bi wire. If you bi wire I’d suggest Audioquest Flx Slip 14/4 cable, I use it on both my setups and find it excellent and it won’t break the bank at about £8/m, if you single wire then the 14/2 variant.
    I'm martin.
    i have a marantz pm14 s1 se and a marantz sa14 s1 se the interconnects are chord clearway
