Results 1 to 10 of 16
Thread: new speaker cable
    I'm martin.
    Default new speaker cable
    i recently asked for advice on interconnects on here and took the advice and went for the chord clearway which made the sound more open and tighter base,i now would like advice on speaker wire,and would it be worth getting a mains conditioner
    Quote Originally Posted by fazerman45 View Post
    My advice would be to tell us your budget before anything else.
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    I'm martin.
    my budget is around £15 a mtr,ive tried some second hand van den hul cs122 but not sure on it
    What speaker cable do you have now?
    (Don't bother with a mains conditioner, total waste of money).
    I don't know much about cables at that price bracket, but they are one of the things that don't age, in fact they often improve a bit as they burn in. So with peoples recommendations I would buy 2nd hand from someone who is upgrading.
    Source
    SW1X USB II
    Amps
    Speakers
    Cabling
    Headphones
    I'm Brian.
    I'm using this and it's excellent https://www.ebay.co.uk/sch/i.html?_f...cable&_sacat=0
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
    Mains conditioners? if its a filter syster, then they can have the opposite effect, but you have to have dirty mains, then a regenerator will help, otherwise they wont do too much, although they will give you a steady voltage and 50hz, which can be useful. wouldnt sell mine.
    as for speaker cable, ive found it can make a bigger difference than interconnects. without knowing what equ you have and cable you use its going to be hard to
    I'm martin.
    what sort of sound has it got
    I'm jamie.
    i use this, https://www.ebay.co.uk/itm/Van-damme....c100005.m1851
    for the price you really cant go wrong,i highly rate it.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Brian.
    Smooth and detailed .
    Regards
    Brian
