Results 1 to 10 of 12
Thread: Con or legit?
    I'm Craig.
    Default Con or legit?
    I appreciate this question relates to something to do with AV, but I needed an answer quickly!
    Is there a difference between a 4K HDMI cable, and one not bearing the 4K ‘label’
    Thanks!
    Bluesound Node 2i
    Audio Analogue Pucinni SE
    B&W DM607 s2
    Klotz ic’s
    I'm AMusicFanNotAnAudiophile.
    Yes.
    Chris
    Common sense isn't anymore!
    Do your devices support 4K?
    Chris
    I'm Gary.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm Phil.
    richer sounds sold some non 4k hdmi cables at stupid prices recently , in order to make way for the 4k
    Eric Bibb
    I'm Craig.
    TV does, don’t think my Sony Blu Ray player does though, it’s at least two years old.
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    If your sources can't dish out 4K there's no need to change the HDMI cables.
    Stick a 4K source in front and play 4K material from it and you'll need higher bandwidth cables.
    Chris
    Is that why that experimental 4K broadcast in the world cup didn't look any different to HD on my set up? I've got a fancy Mark Grant HDMI twixt box and set but it must be 6 years old at least.
    Could be part or all of it.
    What does the hardware consist of?
    Chris
    Virgin cable box, latest one, only had it in a couple of months, 4K ready, and an LD TV, also 4K ready. Bought that last year, it was bin end but deffo 4K.
