Here Marco, something for the good people of Wrecsam:
https://youtu.be/kESOU80uWzc
Or something a bit more mellow. Maybe not for the Brabster, it's here because I like it.
https://youtu.be/vUzVCw8BEXA
Just one more:
https://youtu.be/tfmAcng7mo0
Like the last one, daftee. Do you approve of your new avatar? I tried my best to catch your best side, which I know is usually your backside
I like this track from Pusha, which is slightly Moby-esque (aside from the lyrics):
I'm matt.
I'm matt.
Been reading up on Cabin gain in cars and long story short, every car is different and the position of the sub will produce different results. Here's a typical gain you would get:
You can achieve about 25db gain at 20hz. That's a hell of a lot. Put most car subwoofers in a home and they'd produce bugger all deep bass.
The fact that I don't know what my car is going to do with the frequency response of whatever sub I choose, coupled with the fact that I don't have any EQ, means i'll be buying blind, so I bought a brand new Rockford Fosgate 12" sub off ebay for £40. The sub gets very good reviews and it models with lots of punch (peaks at 60hz - assuming my simulations are anywhere near). With my current speakers I have to turn up the bass to +2 to get a balanced sound. looking at the Alpine head unit manual, the bass boost is at 60hz, so matches the Rockford.
If I don't like it, at least I can measure it, in and out of the car to find out what the cabin gain is. It was only £40 so not much to lose.
Nice one, mate. That should work well. Interesting about the gain thing, too...
You're right. If my B2 sub was in the lounge, it wouldn't be any where near as effective. However, the hardest thing to reproduce in a car is extended low-bass, simply because of the lack of space for such low notes to develop, which is where porting comes in, and why my installer paid due attention to that key aspect of the build
Back to music... Are you into Kosheen? This track contains some bad-ass bass:
I'm matt.
Here's an interesting article on wavelengths in room. Long story short, you'd need a massive room to get accurate bass down to 20hz. You can see why so many people have problems with low frequencies (bass boom, peaks and dips etc).
Yes, quite like Kosheen.
