Results 1 to 10 of 10
Thread: Upgrade thoughts
    I'm John.
    Default Upgrade thoughts
    Good day
    Looking to upgrade. Have already started by buying secondhand speakers Monitor Audio TX6
    Next thought the Amp. I have Nad C325 is this good enough with the new speakers or should I ideally upgrade ?
    Next Cd played needs upgrade. Secondhand £250 mark and recommendations please ?
    John
    I'm John.
    Correction RX6
    I'm Luis.
    Cd player?
    This is the 2018...
    Enviado do meu HTC_M10h através do Tapatalk
    Quote Originally Posted by SantanaCorreia View Post
    Cd player?
    This is the 2018...
    You don't like vinyl then?
    I'm Luis.
    I do but the network player is much easier.
    Amp could be better but is good enough. Cd players - everyone will recommend their favourites and so will I - Something from the Sony 'ES' range or ideally a Technics SLP1200 although not easy to find one for under £250 but it can be done.
    Or a lot cheaper if you can find a working one, the Cambridge CDS4E. The only 'budget' player that has really impressed me.
    I found bypassing the nad pre stage in my c350 with a relatively cheap passive (eg. Tisbury) yielded great results.
    I'm John.
    Hi Lawrence
    I am very new to aspects of hi-fi
    I would like to send you PM because I read advise on bypassing
    John
    I'm steve.
    Buy a second hand Macmini, add an external CD/DVD drive and import all your CDs into the iTunes library, then use the computer as a music server. Either use the headphone output into an analogue input, or use the optical digital output if you have a DAC.
    Stick with your cds !! This stuff on a server thing is boring,I'm going back to cds first chance I get
