Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: Ears, amps and Speakers.
    I'm Rob.
    Default Ears, amps and Speakers.
    Hello All,
    I'm suffering a touch of tinnitus lately and with my setup KEF 103.2s, Sony 770ES amp and a Caiman SEG dac there's a decent amount of detailed highs. The amp plays at a fairly fast pace and when combined with the KEFs which are for the most part neutral (to my ears), but can go high, sometimes sound a bit fatiguing. I'm just not sure about the tonal balance of the SEG?
    I really like these KEFs and don't want to blame them too much, It's probably a synergy thing, but speakers having the greatest effect on a system, I'm thinking about trying another pair.
    Has anyone heard Monitor Audio R852 speakers, there's a pair I can have if I want them? I'm particularly interested in the mids and treble.
    Or Celestion Ditton 15's?
    The KEFs are awesome performers, but I'm am willing to make a compromise.
    Cheers,
    Rob
    Ids there an established link between listening to high frequencies (at normal levels) and the exacerbation of tinnitus?
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    Quote Originally Posted by meBob View Post
    Hello All,
    Cheers,
    Rob
    Is your tinnitus temporary or permanent Rob.?according to my ENT consultant ,tinnitus is basically the brain trying to fill in the gaps of hearing loss.it might be worth having a hearing test.i have some hearing loss in my right ear,high frequency, and now use an nhs hearing aid just for tv and music and found it helps reduce the tinnitus. It's not perfect but has definitely increased my listening pleasure. So, I probably wouldn't go changing anything until I'd had a hearing test, Jim
    I'm Phil.
    i did know of a chap who had to sell his harbeths becuase of Hyperacusis . there are many other speakers you could try such as sonus faber , spendor perhaps .
    https://www.nhs.uk/conditions/hyperacusis/
    Eric Bibb
    I'm Rob.
    Hello Bumpy,
    Thanks for the reply.
    I'm clueless if there is any research on the subject out there, I'm just going by what I feel at the end of a listening session. I wouldn't want to trawl through arcane medical documents to eventually find the answer that I suspect I already know (see my answer to Pieoftheday).
    I'm Rob.
    Hello Pieoftheday,
    Yes It's permanent (sadly), I've been to the doctor and tested and as anyone who has gone to a doctor with this complaint will know from experience, it is that all they can really offer is professional concern and commiserations.
    Sometimes it flares up and the recedes, it's flared up for quite a while now.
    Bumpy has rasised the question above, he might be right?
    It might not be tinnitus at all, it may well just be my system. Although I feel I have not a lot to lose by trying new speakers.
    I'm Rob.
    Hello hifinut,
    It looks like a whole new tin of worms and just like tinnitus there's no cure.
    A cheaper option would be a graphic equaliser, that would let you adjust frequency bands until you find a balance that does not aggravate your condition. I know it isn't exactly purist but you can get high quality units from Klark Teknik if you are especially picky about such things. Although I'd start by buying a cheapo used one to experiment with first.
    I'm Phil.
    always good to try other speakers , i just sold a beautiful pair of speakers that made my feet tap but i noticed they made my ears ache after a while . can`t quite explain it . sadly they had to go , it might have been the lively room that exacerbated it . they did not do it in my lounge full of sofa`s and curtains etc
    now got a pair of speakers that you can play as loud as you like for hours with out any problem . get round to some friends and see what theirs sounds like and what you can cope with
    Eric Bibb
    Hello Pieoftheday,
    The British Tinnitus Association may be of help,Jim
