Ah, I get you now. Sure, I don't doubt it. That won't necessarily be the case though with another 50W amp, which employs a different type of topology
My experience of solid-state Class A amps, done well, is a bit like it is with good valve amps, in that their loudness capabilities belie the power (on paper) they're rated at, and so sound rather louder/more powerful than you'd expect
I reckon it is to do with the current delivery, as I said earlier on. Not the watts. Going from 100 watts to 200 wats is only 3dB louder which is noticeable but not a lot. Then you're up to 400 watts just to get another 3 dB and after that it starts getting silly. But if you're caning it and the power supply starts to sag that's when you hear it start to fall apart.
Just had a listen to another 'Class A', a Monarchy amp that used to belong to Geoff. A very good amplifier, goes on my approved list.
It has had a proper clean on my Moth but that was a few years back so I guess it's picked up a few bits again.
Its here!!!!
It's also a MK2!!
Good grief it's heavy.
Got some paint on, missing some feet but nothing untoward about the sound at the demo. Looking forward to getting this plugged in.
