Results 1 to 10 of 13
Thread: Screws needed
    montesquieu Guest
    Default Screws needed
    I need to replace some little black screws that have rusted on a component (the usual short rounded/cross headed screws you get on lots of different hifi gear, I don't know what the size is though)
    Anyone know where I can find them?
    I also need a thumb-operated screw on cap for an earth binding post, again don't know the size .. I'm thinking though I might need to replace the whole post?
    I'm Josie.
    Hi Tom.
    I have used accu.co.uk
    They have some great quality screws etc.
    Sent from my 9001X using Tapatalk
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
    I'm jamie.
    if you measure the hole they screw into it will tell you the size
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    A small error can mean you get the wrong one, metric vs imperial, then there's the thread size too.
    For little money you could get a hardware pack that will give you a clue what size you need, plus some spare bits.
    http://www.ampmaker.com/store/Hardware-pack-2.html
    http://www.ampmaker.com/store/Hardware-pack-3.html
    Once you know the size there are plenty of on-line hardware suppliers.
    Alternatively I could send you a couple of M3 and M4 screws to see which it is you need.
    montesquieu Guest
    Thanks all and those hardware packs look good though I was after black ones really I wonder if that's doable?
    The holes are hard to measure with the plastic ruler I have but they are either 2mm or 2.5mm.
    trick was to use the pack to gauge size of hole so you order correct screw of length and colour/shape etc.
    I'm Gary.
    Go to your local Engineers Supplier, take a screw with you. They will size it for you and you will probably have a selection of head and material available. You'll probably have to give them 50p for the tea tin!
    I'm jamie.
    hi tom,if you are not in a big rush you can send 1 to me if you like,i have a big nut and bolt store near me and i can take it there and get it matched up.
    My System
    John Wood KT88 Amp.
    montesquieu Guest
    That would be fab Jamie.
