I'm Rob.
Hello Lawrence001,
You've given me an anxiety attack now!
The foams feels uniform I can't find any weak or soft spots.
The previous owner said he's had the crossovers done and listening to one of those Youtube audio frequency sound files everything sounds ok.
I'm Rob.
The Kefs are 103.2s
I've just listened to Pink Floyds' Dark Side of The Moon live, the air between instruments/vocals is superb, there's cripsness to everything delivered with real thump.
I think any issues I may have are probably synergy ones. When I turn the volume up and move back away from the speakers I start smiling as above.
The speakers are either side of a desk I often sit at while on the PC, I'm thinking also maybe my setup isn't conducive to this near field listening.
Nope they will improve from a wider space all round if possible
I'm Rob.
I'm now having terrifying visions of having to rearrange my furniture, this would probably expose collections of dust deposited over many a decade with new life forms unknown to science within.
I agree things could be improved, it's way too cramped the space my speakers are in.
It will happen on one of those days were my energy and optimism levels are both miraculously above normal (and I'm not hung over from the night before).
You're ok, it was the 103.3 and 103.4 that had the foam rot issue. Set aside an hour or two to sort it all out, once you finally do it, it's much quicker than you think
