Results 1 to 10 of 19
Thread: System beginning to take shape
    I'm Robin.
    Default System beginning to take shape
    Regards
    Robin
    Pathos Classic Remix Amp, dac
    Cyrus Signature phono stage
    Eversolo DMP-A6
    Cyrus CD i
    Sure is Robin. Nice compact setup.
    I'm Robin.
    Cheers
    Grant
    Regards
    Robin
    Eversolo DMP-A6
    Cyrus CD i
    I'm Ben.
    have you got room to move those speakers further apart mate?
    Technics SL1210 with
    SME IV Arm & AT OC9XML,
    Firebottle modded Tron Convergence Phono Stage,
    Bluesound Node 2i, Technics SL DZ 1200 CD
    Denon PMA1700ne amp
    Yamaha NS1000M Speakers.
    I'm Robin.
    Quote Originally Posted by Zoidburg View Post
    It’s a bit restricted Ben, but there are is a little bit of room
    Regards
    Robin
    Eversolo DMP-A6
    Cyrus CD i
    How far are they apart, Robin (measure it)? They do look rather close together (and also too close to the equipment itself), certainly in order to perform optimally.
    Is the other end of the room any wider? If so, it will almost certainly sound better employing the use of longer speaker cables, and putting your speakers there, if in the end you can get them further apart. What is it, an attic room?
    aye, if you can get the triangle it will help with imaging
    I'm Robin.
    Marco, yes it’s an attic room, and that is really the only place will try and move them further apart I have moved slightly and they are 1 metre apart might be able to push that to 1.5.
    Regards
    Robin
    Eversolo DMP-A6
    Cyrus CD i
    I'm Robin.
    Working on it Grant
    Regards
    Robin
    Eversolo DMP-A6
    Cyrus CD i
    if your not too much more than 1.5m away then you can try toe ing them out a fraction as well.. not much tho 5o
