Results 1 to 10 of 10
Thread: [emoji23] one for the man cave ? Teleton SAQ-206B
    Default one for the man cave ? Teleton SAQ-206B
    Looks like crap and I don’t have the correct din cable to test it properly so I can only hear it through the right, and the power light doesn’t work which is why I suspect it was sold as not working.
    Skip or save ? Owes me a whopping £23.
    Yeah, save it.
    That case can be tidied and the internals are not complicated. If you only have output from one channel, it could be down to something as simple as a dirty control.
    Ok I’ll have tinker with it
    yeah, keep yir knob clean
    I’ll use the wife’s sucking machine on me knob(s) then
    As an amplifier it's a nice little one for a starter system. In its day it was often paired with something like a Garrard SP25 and say an Audio Technica AT66 cartridge with some budget bookshelf speakers. I believe the output is 6W/channel, so that will limit the range of speakers with which it can be used.
    If it were me, I would refurbish it and find someone who might use and enjoy it. Failing that, give it to a charity shop of your choice. Don't bin it - there's far to much stuff going into landfill as it is.
    I definitely won’t bin it
    I'm inactive.
    I had one back in the time - with the dinky bookshelf speakers ... wasn't bad at all:
    Quote Originally Posted by mikmas View Post
    My father used one in his system, driving Wharfedale RS8/DD drive units in Wharfedale design 1.5 cu ft distributed port enclosures. Didn't sound too bad at all.
