Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
Thread: What type of cable has the biggest impact on SQ?
    I'm Adrian.
    Quote Originally Posted by Stereosane View Post
    That is a tuff one.. I found the most significant change was using the same brand of cable for all three which gave me the most noticeable improvement, I guess there’s a synergy when using the same brand.
    Best is to lend a few cables and play around.
    Completely agree, I did the same and also had a few demo cables, I have ended up with a mix, but found Chord for speakers and Ecosse for interconnects suit me best.
    I'm Clive.
    Thanks guys for all your answers. Some of you may have misunderstood my intention.
    If I asked what has the biggest impact to SQ between speakers or amplifiers, which would you buy 1st. I’m deliberately not asking about source as that would invariably open a can of worms. I would hope I’ve made my self a little bit clearer.
    TV LG55B7 OLED
    I'm Neil.
    Quote Originally Posted by Clive197 View Post
    I’d buy speaker cable first, because I have been able to spot differences more readily.
    If you cant hear improvements by changing things like mains cables, then I would start changing components.
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    I'm Neil.
    Default What type of cable has the biggest impact on SQ?
    Blind testing is a good idea too. Not some horrible group ABX session with unfamiliar gear, but single component changes. I know subjectivists can pooh pooh it but it’s very interesting, for example, running 2x identical transports & CDs with different cables, and flipping between the two with your DAC’s source selector, or preamp if using the analogue outs. This was very very eye opening for me.
    I had no issues, for example, in spotting the differences between Tellurium Q Black speaker cable, and my LFD Hybrid Ribbon cable. I also experienced a strange brightness when using a power cable, which I swapped out and alleviated the issue. Am not saying this stuff doesn’t make a difference...
    I'm Gary.
    Weirdly, a new perspective for me, HDMI cables used for i2s connection have a bigger impact on subjective sound quality swapping between them than any other bit of wire that I've tried.
    Over the years I've tried a lot of different interconnects, speaker cables, power cables, DC cables from power supplies...all made a difference, but I'm hearing more variance swapping between HDMI cables running i2s.
    Mad as it sounds, that's what I'm hearing.
    Fascinating.
    Clive,
    between speaker cable and interconnects I'd go with speaker cable.
    The boxes that produce the sound are the most important factor for me, and getting the "speaker output" right (speaker+cable=synergy) makes the biggest impact in my experience.
    Room > Speaker > amp > source IMO
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm AMusicFanNotAnAudiophile.
    That's probably because I2S was never intended to have 1m plus cables connected between digital and analogue stages.
    It's intended for internal use over millimetres between adjacent ICs on a PCB.
    Chris
    Common sense isn't anymore!
    I'm Gary.
    Your right Chris.
    0.3m Wireworld Platinum Starlight I think, toast n beans for another couple of months.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    Your right Chris.
    Cheapskate!
    That's only £470.00 more than I'd consider using
    Chris
    I'm Gary.
    Cheapskate!
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
