Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Help: Bi-wiring and cable thickness?
  1. #21
    I would not bi-wire. Get a decent set of jumpers ( spend £50 tops) and use the thickest multi-strand copper cable you can get, single run into the bass terminals. Connect the jumpers between the bass terminals and the hf terminals and you're good to go.
  2. #22
    Modern B&W are never an easy load so I would not recommend using both A and B speaker outputs at the same time. The amp will shut down or blow a fuse. Been there, done that, as have countless people.
  3. #23
    Quote Originally Posted by Exophile View Post
    5% of speaker resistance for cable resistance, that would permit for some very long cable runs! For 8 ohm speakers that would be 400 milliohm resistance, so 50 m / 150 ft for AWG 14 wire! Even if I reduce that by 1/3 for LF, then I still have 100 ft of run.
    Not quite - the loop resistance should be no more than 5% of the nominal speaker impedance; that is the combined resistance of both wires. A figure of 5% is chosen so the damping factor is not reduced to less than about 20. So a loop resistance of no more than 400 mOhm implies a speaker cable length of no more than 78 ft, if the two wires are AGW 14. Still pretty long for a speaker cable; but up to a couple of years ago my speaker cables were 50 ft in length.
    https://www.cirris.com/learning-cent...lculator-table
