Results 1 to 6 of 6
Thread: Can I use any old wire for earthing my turntable?
    I'm keiron.
    Default Can I use any old wire for earthing my turntable?
    I've got a new Technics SL1200G turntable.
    However, the earthing wire that came with it has spade lugs that aren't big enough for the post on my Lehmann phono stage.
    I'm loath to snip the Technics wire, so can I just use any old piece of cheapo wire from my spares box? Or does it have to have some fancy shielding or something?
    No it's just copper wire.
    PRE
    I'm Adam.
    But make sure you get the direction of the cable correct, otherwise the hum will get worse...
    Quote Originally Posted by Beobloke View Post
    Thats right Adam, all the electrons have to face the same way otherwise dreadful hum )
    GyroDec 2M Black, Amplification: Luxman 505ux.
    Loudspeakers: Harbeth HL-K6
    Quad 99 CD, Amplifier: Teac A H 500i, Loudspeakers: SCM11
    Receiver: Teac CR H500, Loudspeakers: B&W CDM 1NT
    Quote Originally Posted by high.spirits View Post
    And make sure the wire is near vertical: it helps if the electrons can go downhill!
    I'm Mick.
    Any wire will work. I have soldered many Technics earth cables to extend them. If it doesn't hum afterwards all should be ok.
    Technics SL1210 MK2 fully rebuilt and repainted. Ortofon 2M Black Cart, Isonoe isolation feet , MN bearing and Funk Firm platter upgrade, Oyaide RCA Tone Arm and speaker cables, Jelco SA-750D Tonearm. Oyaide HS-TF Carbon headshell, MCRU Linear External PSU, High Fidelity Crystal glass turntable matt, Blue LED upgrade, Denon AVR-2808CI Amp, Bowers and Wilkins DM602S3 Speakers,
    Black Rhodium Jazz power cables for amp and turntable, Firebottle mk2 Phono Stage.
