Page 22 of 23 FirstFirst ... 1220212223 LastLast
Results 211 to 220 of 222
Thread: Bigbottle MC Phonostage
  1. #211
    I'm Oliver.
    Quote Originally Posted by nuff View Post
    Good morning all,
    Would the power supply in the link be suitable or is there another you would recommend.
    https://www.ebay.co.uk/itm/192498606...torefresh=true
    Ah, sorry mate, I have been negligent here! I completely forgot.
    If you want total silence, you must either use Toroidy.Pl or similar custom toroid manufacturer.
    Avoid Airlink. the last three I had from there have a mechanical hum which I hate with a vengeance.
    The one in your link is fine but as Alan said some shielding will be required. Loads available in China for £10 and they work really well.
  2. #212
    I'm Nathan.
    Yes that transformer is suitable, I have used the same one myself.
    However there is a caveat. The tx isn't a toroid so the magnetic field is greater, unless you shield it very effectively or have a large case so it can be positioned far from the MC inputs you may have problems with induced hum.
    Also with the construction a lot of these examples have a low mechanical hum/buzz to them. If you want silence then look elsewhere.
    Thanks for the help Chaps! I'll look about a bit more and see what I can find
  3. #213
    I'm AndyElectroNumpty.
    I got a potted one from toroidy for about £60 more expensive than some but good quality and good service from them. You have to email them and they'll send you a quote etc as it's not part of their normal range.
    At the cutting edge of Numptyness!
  4. #214
    I'm shahrin.
    Hi Oli
    this sounds like a great project. i ve had a cursory read of this and related threads.
    Is the PCB still available?
    How does this compare to your Moon phonostage ?(All change at Big Bottle thread).
    Smangus havin problem on his build ?
    ta
    S
    Thorens td124 mk2 / 3012 S2 / SL15Q / MC15 Super II
    Marantz CD63 / Squeezebox Touch / Nak CA5 / ESP eXO / Sansui AU111 and Nak PA7 amps / JK Wynn semiactive NS1000 upgrade
  5. #215
    Hi Sharin, Oli is no longer posting on this forum.
  6. #216
    I'm Mark.
    Is that a bit of a Christmas flounce over the “Boris Big Win” thread? Another reason why (IMO) discussion of politics (and religion) should be banned...
    100% Analogue
  7. #217
    I'm shahrin.
    Oh dear sorry to learn that . I hope all s well ...
    Alan, the phonostage is your design i believe.
    I m looking to upgrade from a Project job with 2 valves sticking out of it.
    My soldering skills are not bad. Feel this device would be something I could build.
  8. #218
    It is Sharin but I don't think there are any boards available.
  9. #219
    I'm shahrin.
    ahso 'limited edition ' then
    Cheers
  10. #220
    Agreed
