Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 150
Thread: Educate me please , Who has a quality dac / streeming setup ?
  1. #61
    I'm Allen.
    I like your ethos mate and agree but I really don't think the Pi route or any of the cheap options will get you to where you would like to be sound wise. An Innuos server is the way to go with a DAC of choice on the other end. The server is more important for sound quality than you can imagine. I was gobsmacked at the difference it made. And it runs nice to use software for your metadata which is a joy to use and it doesn't fall over constantly.
    £700 for a entry level unit , Then £1500, £2300 and £5000 , Yiks
  2. #62
    I'm Edward.
    I have been using my current Rpi player for nearly a year now, It took me 10 minutes to install and configure Volumio and I haven't had a problem with it in all this time. The only challenge I faced was finding out how to play Tidal through Volumio. That was resolved though this forum with very little effort. The only maintenance required is to check periodically for new updates and to install them. This is done without having to remove the sd card, through the Volumio browser. I should add that I have never had to connect a monitor or keyboard to set up the system. I know nothing about Unix either nor do I wish to learn it.
    I am very impressed by the ease of use of Volumio. I noticed a recent upgrade has allowed me to add high bitrate web radio stations directly by typing in their url address. I have recently added most of the BBC 320k sites as well as some even higher resolution "audiophile" stations.
    Geoff
    Care to share these links please Geoff? In particular any classical or jazz music channels.
    cheers
  3. #63
    I'm Adam.
    Quote Originally Posted by Edwardlon View Post
    cheers
    Jazz24 always sounds incredible!
    "lack of passion is fatal"
  4. #64
    I'm Edward.
    Quote Originally Posted by WESTLOWER View Post
    Pah! Only 64kps AAC mate.
    But excellent playlists.
  5. #65
    Bigman80 Guest
    I think you have to accept it for what it is, a file based system and I'm ok with it if I can do it on the cheap. I sold the XiangSheng because I needed to raise some funds. I could've carried on with that quite happily. It wasn't up to the Analogue side but it shouldn't be. It was easily as good as a cheapy CDP though. The Pi could be a solution in terms of attaching a HDD and control with the phone which I'd enjoy.
  6. #66
    I'm Adam.
    but it sounds very good... all just numbers the other stuff Edward!
  7. #67
    I'm Edward.
    We're gonna have to have a serious chat someday Mate. There's numbers and numbers I have you know.
    Seriously though AAC always seems better than MP3 at the same rez. Not sure why. Probably the best bits are not thrown away.
  8. #68
    cheers
    The 320k BBC urls are here: http://steveseear.org/high-quality-bbc-radio-streams/
    Other high bitrate stations here: http://radiobit.50webs.com/
    Geoff
  9. #69
    I'm AMusicFanNotAnAudiophile.
    Well I tried I got squeezelite running. downloaded and got lms running but that was all. couldnt get it to do anything else..
    what we need is a blow by blow account of setup, including explanations of what the boxes mean.
    There are a few steps you need to do to get things going properly.
    When you have LMS up on a web browser you'll find a settings button down on the bottom right hand corner.
    Click on that and another tab and page will open up.
    If you go to the plugins tab you can enable various apps - they're all found there, but quite a few are not enabled.
    Chris
    Common sense isn't anymore!
  10. #70
    I'm Edward.
    Thanks Geoff. Lots of playing ....
