Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 150
Thread: Educate me please , Who has a quality dac / streeming setup ?
    I'm Allen.
    Default Educate me please , Who has a quality dac / streeming setup ?
    OK , Go on then , Educate me
    I have a DAC 3 purchased from Jerry of this forum , I have been told by other forum users its not that good chip wise
    What do I need to hear these wonderfull sounds that reputedly better vinyl , I am willing to learn , I have itunes and Amazon music
    over 2 you
    I'm Gary.
    Interesting question
    Current digital setup is just as good (but different) as my vinyl rig, a Michell Gorbe, SME V, Dynavector XX2 Mk2.
    Pretty good disk spinner that, so digital's got to be too to keep up.
    It is.
    My Dacs a PS Audio Directstream Dac with Bridge II network card fitted.
    Music comes from selfbuilt Linux server running Roon, which is piped directly into the Dac.
    Sounds terrific I think, certainly as good a dac as I'll ever need.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm Edward.
    You probably have all you need to get great tunes without having to spend money at this stage. Get things working initially and then consider changing things.
    Highly recommend you don't use itunes and amazon music - best to start with local files in flac or wav format and use a quality software player (e.g. JRiver, Roon etc - lots of choices) and make sure the player is playing directly to the DAC (rather than via the operating system mixture) so your DAC gets bit perfect data to decode.
    What type of computer are you using? PC, Mac or Linux?
    FWIW my audio path is: FLAC (either local or via Tidal) > Win10 server > Roon player> Win10 fanless endpoint > USB > Metrum Hex DAC > Preamp etc.
    Lots of different ways of doing things. Mine is just one way.
    got several ways to do it here. the rpi and audiophonics dac board is good, currently with volumio2 installed and a local disc but can be streamed to via spotify and jriver, but hope to get the software changed at some time. its not bad at all for a free program.
    Jriver on my laptop with local flac files either into my smsl dac/headphone amp, or to my xaing sheng dac via usb cable. can also send spotify down to either dac.
    They are all pretty decent.. TT is decent too imo, and although not at levels of most here, it sounds good and uncoloured to me.
    I'm Allen.
    Highly recommend you don't use itunes and amazon music - DOH ! , Amazon cost £79 per year and Itunes is £10 a month , Dont want to be spending even more money every month best to start with local files in flac or wav format Did I mention being a numpty with computer files and use a quality software player (e.g. JRiver, Roon etc - lots of choices) Is this something else I need to buy ? and make sure the player is playing directly to the DAC (rather than via the operating system mixture) so your DAC gets bit perfect data to decode.
    What type of computer are you using? PC, Mac or Linux? I have a iMac
    FWIW my audio path is: FLAC (either local or via Tidal) > Win10 server > Roon player> Win10 fanless endpoint > USB > Metrum Hex DAC > Preamp etc. Is this ancent hieroglyphs
    Goes over my head
    I'm Kevin.
    I am going to try an Asus DAC on a soundcard for my PC to see what it is like compared to my super cap Caiman SEG.
    I am also going to see if it gives a decent SPDIF out direct to the Caiman.
    Then I want to try a Digione player feeding the Caiman.
    I think a good streamer is the SOTM 200(?) but it is expensive.
    Kevin
    I'm Allen.
    Just noticed im at 8000 posts , good god get a life man
    I'm Edward.
    Al
    Just plug the DAC into your mac and connect it to your music system, start up itunes and press play. Then sit back and enjoy.
    No Egyptian writing or things going over your head or having to learn new things.
    I'm Allen.
    Quote Originally Posted by Edwardlon View Post
    Al
    Hi Edward
    Alread done that via optical cable , far from impressed with the sound quality
    Goes over my head
    stick with the big black pizzas til someone comes and sets something up for you is my advice Al
