Jolida FX Tube DAC DSD Tube DAC/Preamp with headphone amp
New, only opened for these photos. Very well regarded and known dac - likely the only or one of the only DSD versions in the U.K.
Can be used as a preamp directly into a power amp for digital only systems or just a quality tube DAC with headphone amp. (Does not use a remote control function).
Comes with the stock TungSol 12AX7 tubes. The boxes these are shipped in are small so a UK plug/cable does not fit. So one only has to add a UK mains cable to get set up. A USA cable is included in the box.
Technical Specifications:
Output Level: 0 V to 2.3V (±1dB, 47K ohms) (SIN SIGNAL 0dB SPDIF IN)
Frequency Response: 20-20 KHz (±0.5dB)
Bandwidth: 10Hz to 70kHz + 1dB
SNR: >90dB (20Hz-20kHz)
Dynamic Range: 126 dB
Distortion THD: Less than 0.01% (1kHz)
Headphone Impedance: 30 Ohms
Construction Details & Features:
Amplification of the analogue signal is done via the vacuum tubes
PCM: 32Bit/384KHz
DSD: DSD 64 / DSD 128
Asynchronous Burr Brown Chip AD1896
DAC Chip: PCM 1795
R Style Transformer
Price £460 incl U.K. post.
