Thanks for your help fellas, but life is too short for this!
Think I'll just plug my Dragonfly into my phone and move the Pi on.
Chord Mojo / Sennheiser HD600
I'm Simon.
p.s. Still enjoying the SpaceDeck!
guessing the hostname will be raspberrypi but no idea how to find it that way. think i cleared all the ips and then started again, putting the rpi on last. its stayed that way ever since.
What options do you see when you log into your router on your computer?
The problem appears to be one of lease renewal, so if you can locate where static IP or DHCP reservation is on the router you can stop the route reallocating things.
You can see here where devices that I do not want to go walkabout on my network have reserved IPs
Chris
Common sense isn't anymore!
Ha, I dont know what happened but I lost control of my moode ips etc didnt work... had to scrub it and try volumio. got that working. crazy old world; that moode has not blinked for an age....
after all sorts of issues volumio2 is working now and with spotify integration. Ive even managed to map the hdd connected to it(that took a while lol) not tried sending anything to it but can see it and the music on it. Win 10 last update screwed with smd etc so was locked out.
I'm Stephen.
I get this with Volumio. When revisiting the Pi after 24 hours break Volumio.local/ does not work. I turn off the WiFi and then back on at the host computer and it then connects fine. Might be worth a try.
in control panel I went into widows features(in programs, turn features on/off, on left) and checked that SMB 1.0 was enabled. one of the 3 wasnt The server. so I manually did it and restarted the pc... seemed to work.
I did try other things too but think that was the one that let me map the network drive(volumio's hdd...)
You need to assign static IP's in your router settings, most provider supplied routers have the ability to change settings locked down and / or aren't as flexible when it comes to anything else than straight forward setups.
