Current system:
RPi + Allo Digione
Beresford Caiman Seg & Dorado powered by 15v Linear PSU
Transcendent Sound Mini Beast OTL
Amptastic Mini-1
Klipsch KG4.5 Speakers with Titanium Diagphrams and Sonicap Cap upgrade
110aH Leisure Battery powers the Mini-1 & Digione
Hifi: Innuos Zen Mini MKIII > Fisual Hollywood Optical > Quad Vena II > Custom Clyde interconnects > TA Monoblocks > Tellurium Black > Reiver Millburn MK II (Custom super tweeters & TQ Black Jumpers).
Headphone Rig: MacBook Pro/Google CCA > Fisual Hollywood Optical > Beresford SEG > Custom Clyde interconnects > Beresford Capella > Sennheiser 700s
All it will do is drain the battery quicker. Unless your pi has a lot plugged into it in which case the buck converter might cause power issues. Out of interest what is the Ah of your battery?
Current system:
RPi + Allo Digione
Amptastic Mini-1
Only thing that'll be plugged into it is a HDMI to a display (has its own power) and an optical to my DAC (has its own power). Fingers crossed I can get it to work.
Honestly, I'm not sure, I bought the battery used from a scrappy for £20 lol
Sent from my SM-G965F using Tapatalk
You should be fine then. Only have to solder 2 in and 2 out wires. Bare in mind the pot to set the voltage can take a number of turns before it starts to move but it will in the end, best to use a meter here.
You may have to butcher a micro usb lead as i did and if you do leave enough wire at the supply end to test for the two 5v feed wires (I think there are 4 or 5 wires in usb cable) and make a note of their colours.
Sent from my SM-G930F using Tapatalk
Current system:
RPi + Allo Digione
Amptastic Mini-1
