Page 12 of 12 FirstFirst ... 2101112
Results 111 to 120 of 120
Thread: The Snake Oil Machine
  1. #111
    I'm inactive.
    Hmm. It gets more complicated as it goes along.
    It gets even more confusing if you try to read around the subject ...
    I found the list below which appears to identify characteristic features of Class I and Class II devices, this was from the website of a firm offering electrical safety checks for businesses.
    On another site, they use actual examples to show that the list is, at best, missleading.
    Class 1 Appliances
    With Class 1 appliances, the user is protected by a combination of basic insulation and the provision of an earth connection, thus providing two levels of protection. When PAT Testing Class 1 appliances, Earth Continuity and Insulation Resistance tests are carried out. So in summary:
    - If it is made of metal it must be a Class 1 appliance
    - If it has a three core cable it must be a Class 1 appliance
    - If the plug has a metal Earth pin it must be a Class 1 appliance
    Class 2 Appliances
    In Class 2 appliances, the user is protected by at least two layers of insulation. For this reason, Class 2 appliances are also known as Double Insulated. They do not require an earth connection. When PAT Testing Class 2 appliances, just the Insulation Resistance test is carried out. So in summary:
    - If the case is plastic it must be a Class 2 appliance
    - If there is a double box symbol on the rating plate it must be a Class 2 appliance
  2. #112
    I was going to cite that site (no pun intended). The Wikipedia entry on the subject is pretty definative, but doesn't discuss testing protocols or methods.
    I'm Adam.
    “If the plug has a metal earth pin it must be a Class I appliance”
    Seriously?. What a load of tosh! Every Class II item I own has a metal earth pin in the plug - it’s just not connected to anything!
  4. #114
    I'm Graham.
    Quote Originally Posted by Beobloke View Post
    Indeed! because if the plug socket is shuttered, it won't open without the plug having an earth pin. (I have seen plastic earth pins, though, but in a plug sealed to the cable.)
    GrahamS - It's not what you hear that counts, it's what you think you hear........
    Present Kit: NAD 326BEE, NAD C515BEE CD player, JVC QL-7 DD turntable, JVC Tonearm, Shure M97Ve, Audio Technica AT95EX, Pickering V15, JVC Z1E, Wharfedale Diamond 230s, Visual Rio interconnects and My Ears.
  5. #115
    I'm inactive.
    Yep - that's the point.
    Everything on the list is missleading bar the last one mentioning the double box symbol.
    The other site I linked to has more examples showing how inaccurate the list is.
    Very confusing considering the list is provided by a firm offering electrical testing services
    Edited to add a link to the other site, scroll down for the examples:
    https://pat-testing-fss.blogspot.com...ppliances.html
  6. #116
    Definative?
    Apologies, but I know you appreciate such pedantry!
  7. #117
    Consequence of rapid typing, and my PC is not set up for automatic spell checking.
    What browser are you using? Chrome, for example, has an automatic spell checker
  9. #119
    Firefox. I can't install Chrome on my machine (it's too old), and I have abandoned Internet Explorer as, since a revision, it won't link to sites that are not https .
    There's spell check in Firefox. Yours may be turned off. This may help: https://www.technipages.com/firefox-...-spell-checker
