Page 2 of 25 FirstFirst 123412 ... LastLast
Results 11 to 20 of 241
Thread: Bye Bye cigs?
    Quote Originally Posted by mac72 View Post
    I've been thinking about vape , which one would be best ?
    You'll be bombarded with recommendations now!
    I have an '88vape' and two 'ecig' pens. Only cheap, but I find the 'ecig' better than the '88vape'. They are £4.99 at Homebargains.
    I’ll be flogging mine !! Along with a fancy all singing charger too
    Wismec gen 3
    I'm Neil.
    I did stop for about 3 months, then back on the cigs. Must try harder...
    I really like MTL style, I went through a phase of building my own coils, dripping etc., but my fave is the Nautilus Mini tank.
    I'm Ian.
    There is a plethora of choice out there but I would recommend getting one with variable wattage as this allows you to tailor the strength and flavour of the vapour. I bought an Eleaf kit and it cost about £45 which you recoup very quickly. Best bet is to go to a vape store, they're usually helpful.
    Turntable
    CD
    Network Player
    Cambridge NP30
    Amplifier
    Speakers
    Cables
    Headphones
    'ecig' £3.95 on ebay: https://www.ebay.co.uk/itm/eGo-1100m...GNC3G5fAmlurYg You might want to get two. One to be on charge while the other is in use. That's what I do. You can buy spare batteries, but at that price, it makes sense to just buy two vapes.
    It's cheap, but works just fine. You can get the liquid on ebay too or at any tobacconist.
    I'm Slav.
    I'll give it a go , thanks.
    Which liquid/cartridge fits this one?
    I currently use the 18mg/ml liquid. Your tobacconist should sell it, you just unscrew the mouthpiece to top-up. Some of the flavours are revolting though. I stick with the tobacco or menthol flavours. Tried cherry a few weeks ago, it was ghastly!
    Vaping is as bad as Hi-Fi. No end of posh gear about at fancy prices, but a cheapie will get you going and you can revise your wants later if need be.
    Dug my one out. All cleaned and unlikely to use again. It's adjustable but I found it too powerful for me these days great tanks
    These may be overkill tho and you might be happiest with something like Geoff has or the cigarette type
    I'm Slav.
    What's strength should I go for , I smoke something between 10-15 a day,
    which brand of liquid would you advice
