Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 66
Thread: Are expensive phono preamps worth it?
  1. #51
    link works for me....and yes it was
    Bigman80 Guest
    Oh?
    Must be a tapatalk issue.
  3. #53
    I'm Slav.
    Quote Originally Posted by 337alant View Post
    Absolutely !
    https://www.diyaudio.com/forums/grou...stage-buy.html
    I wish I had joined in this one too
    looks excellent and very simple to build
    Alan
    Not sure about this one , with no circuit diagram (one could take it of the board but it's too much hassle for DIY) and no measurement reference points it's pretty useless as one don't know if works as intended . With something like this you definitely need an oscilloscope to see what it does , at least on the output.
  4. #54
    Bigman80 Guest
    Quote Originally Posted by mac72 View Post
    I'm afraid not, Mac72
    There are measurement point available, which are provided to those who've bought a PCB. The Circuit diagram is not provided as it's not mine to share, as I repeatedly state in the thread.
    You've obviously not read the opening post on this and jumped to a conclusion. The wrong one.
    The PCB was designed so all you need to do is buy the parts listed on the BOM, included are part numbers so you can buy the exact ones specified. You then follow the build guide, which is incredibly simple. You then have an exact replica of the three I have built.
    I checked this approach works by doing exactly that and to see if it yields repeatable results.
    It absolutely does.
    The RIAA network was the only tweak required after the last build with the new board and that has been done. If you put the parts in this PCB that I have specified, the results are the same and the measurements are eerily close. I just mention again, I have tested this theory physically.
    I even spec the Transformer so there is no chance of error there.
    This project is a "paint by numbers" approach so that ANYONE can build a phonostage WITHOUT the need for specialist equipment. That was the whole point.
    All you need to build this board and check it's ok, is to own a soldering iron, be able to solder and own a multimeter. Both of which can be bought for under £20. If you can follow instructions well enough to bake a cake, you can build this phonostage.
  5. #55
    I'm Slav.
    I cannot see anything about reference points in the opening post , tbh i scrolled down to Gerhard's post asking about the diagram and it was it .
    Haven't realised it was yours , oops
  6. #56
    I'm Slav.
    But still if I were to build something I'd rather see how it works and what it does , we all make mistakes , parts are not repeatable , etc...
  7. #57
    I'm AndyElectroNumpty.
    I built my Dcb1 without looking at a circuit diagram. I wouldn't know what it is about even if i had it so made no difference at all to the out come. But that is a well trodden path with a lot of online resource out there, and here
    Sent from my SM-G950F using Tapatalk
    At the cutting edge of Numptyness!
  8. #58
    I fairly recently bought a new Phono stage, of which im very pleased with. A project phonobox ds2 usb...a bit of a mouthful
    Sounds very good, and is very easy to adjust with buttons on front. It also can play it over optical on the fly and record via usb to pc. (which works very well with a good program)
    Was a lot of money for me but I am enjoying it and love the flexability and rhe recordings you can make for the digital side are pretty good.
    Bigman80 Guest
    Oops!
    No need to mince your words just because it's mine, I'm not offended, I just wanted to explain the availability of the aforementioned information.
    I haven't made all the information available on the thread but if anyone has had a question about Gain, Loading, measurement points, alternative parts etc, I have all of that and will share it with anyone who's bought a PCB. It really is a very simple project and one that in personal research has been very reliable. If it wasn't, I'd never have offered them out because I don't make anything on the PCBs. It was a not for profit project. I don't own the circuit, I didn't design it and would never suggest I have the ability to do so. The plan was to see if any electro-numpty, like me, with a soldering iron and will power, could build their own phonostage. I can tell you from first hand experience that they can IF they do exactly what the BOM and build guide says.
    No fancy equipment is required and that was the goal! It's like a jigsaw puzzle and once you put it together, there should be no variation between any other Bigbottle phonostage.
    I knew there's be resistance to the project because I won't share the circuit diagram but you don't need it, not for this project anyway.
    O
  10. #60
    Link isn't working mate, is that to my Bigbottle phonostage?
    If so, it's not too late to join in!
    If not, I'd like to see who else had the same idea lol
    Sorry yes it was your bigbottle and yes I will take a board or is it 2 boards ? PM me
    I downloaded a copy of the BOM
    Alan
