Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 153
Thread: Chester Hifi Show 2018
  1. #121
    Had a set of big missions with side firing woofers. Never hot on with them but my mate got them and loves them. Horses for courses
    Listening only tells you what's going on, to find out why it's going on you need to do research.
    Yesh, but I don't really care about the whys and wherefores - simply the results of what I hear!
    You're right, Martin, but as you know, with hi-fi, I go more on my gut feelings/instincts (which rarely let me down) than on technicalities, and my gut feeling in this instance, is indicating that there's very likely something in what I'm saying. However, if that's true, it would be interesting to see some objective proof that confirms it
  3. #123
    But nevertheless you are speculating as to why you hear it so you must have some interest.
    My gut instinct agrees with yours, though. Maybe Frank Cooky knows the score on this?
  4. #124
    Appropriately driven (e.g. with my old Krell KAV250a amp) my 2 sidefiring 8 inchers per speaker even impressed Justin with the bass slam they could deliver. Justin is not easily impressed in that regard.
    It's all in the implementation, imo, handy rules of thumb don't always apply.
    As you know, I enjoyed your MBLs, and to my ears they didn't lack slam, but your MBLs are less conventional and not the type of floorstanding designs I'm criticising. It's speakers such as the Audio Physics you posted a picture of earlier.
    For me, speakers like that are fundamentally flawed, and cause havoc with rooms (in terms of how the bass they produce 'excites' them).
  5. #125
    Lol - indeed. Btw, I'm happy to speculate in public about anything to do with hi-fi - call it 'thinking out loud', but it doesn't mean I'm right. Indeed, I'm quite happy to be proved otherwise, as it's all about learning stuff!
  6. #126
    Now you see, that's *exactly* the type of slim-baffled large floorstanding speaker I don't like, with side-firing bass drivers, which simply don't produce the same slam and scale, as the likes of the smaller Hecos above, with one front-mounted single 12-inch woofer per speaker, although they certainly have plenty of deep bass.
    However, as I've said before, deep bass and palpable scale/slam are quite different things - and in my experience with floorstanding speaker designs, one front-mounted, say, 12-inch woofer, will excel at the scale/slam thing more than 2 x, say, 8-inch side-firing woofers.
    Theoretically, you might have a total cone area of 16" inches, but in practice, the one front-mounted 12-inch woofer will still produce more scale/slam (given that the internal volume of the speakers in question is the same or similar)! That's what my experience tells me anyway
    Have you ever heard KEF Blades. They may make you think differently about what side firing speaker systems can do.
  7. #127
    I'm Neil.
    My Anthony Gallo Reference 3.1 and 3.5 speakers also have a side firing bass driver. I think the problem for me with conventional cabinet designs is I can hear the cabinet and wide baffle speakers, those I have heard, don't image as well as narrow baffle speakers.
    Regards Neil
  8. #128
    Hi Jim,
    No I haven't. I'm aware of them, but haven't heard them. I'd certainly listen to the Blades with an open mind, but I doubt they'd be my thing. You never know, though!
  9. #129
    I'm Simon.
    The edges cause diffraction, so act as an independent source of sound.
    The wider they are apart the more diffuse and spread out the imaging will be.
    The somebody who wanted infinitely wide baffles wanted to get away from diffraction effects altogether.
    Unachievable, of course.
    Except without any baffles.
    The wider apart they are the lower the frequency diffraction effects act at as well. Go low enough and bass is omni directional anyway. Its not as simple as wider equals worse imaging, far from it.
  10. #130
    Quote Originally Posted by Dalek Supreme D L View Post
    Sure, and at the end of the day all speakers are a compromise. And although I care about it to a degree and consider it as important, I'm just not a big imaging/soundstaging freak. I'm more a rhythm/boogie/scale/slam/fun-factor kinda guy, so would always choose speakers that majored on that, as opposed to the former.
    However, in terms of my own speakers, they might have big cabinets with wide baffles, but the very nature of the Tannoy DC design ensures that imaging is very good, whereas with other large loudspeaker drive units, in similar cabinets, it might not be.
    The other thing to consider too, if you scroll back to the pics of the Hecos I posted earlier, and examine in particular the larger of the two models, you'll see that they may be rather wide, but they're not very deep, and for good reason...
    So there's not as much cabinet to 'hear' overall, with such designs, as you might think - and what's there will certainly be inert
